Question about ASUS P5VDC-MX Motherboard
Problem with the P5VDC-MX to display 1680x1050 resolution
Bought a new SamSung 226BW monitor but when I changed the resolution setting to 1680x1050...screen just flickered and jittered like crazy. Frequency is set to 60Hz(recommended) but I also tried different luck.
Already updated Bios(version 0805 ofr P4M800 Pro dated Jun 20 2007), also updated the S3 Unichrome Pro IGP driver from its website....also updated Samsung latest driver...still same problem.
  • 2,351 Answers
If you go to the FAQ section for your board you will see that the screen resolution can only go to 1600x1200 UXGA, UXGA+ res name pixal depth 8/16/32
FAQ page 4
Posted on Dec 31, 2007
Monitor screen goes blank often.we r havins asus motherboard P5VDC-MX P4M800 PRO CHIPSETSUPPORT.
It may be that your display resolution is set for a resolution not supported by your monitor. Since you did not specify the type of monitor or operating system I suggest that you go to Control Panel and select Display or Personalization and set your resolution to something like 1024 x 768 60 hz and see if you have the same problem. If the problem has disappeared then select a resolution compatible with your monitor.
Sep 08, 2011 | ASUS P5VDC-MX Motherboard
If i try to connect to 1680x1050, my screen goes dark. but when im using 1600x1000 it still desplays
The resolution 1680X1050 is the native resolution for your monitor. This means that the best view for your monitor is for this resolution. Your problem in not at the resolution, it's at the refresh rate. How to fix this? Go to the settings for your screen. At the lower right corner you will locate "for advanced users" button. Click on it and choose the "screen" tab. At the lower part of the window you will locate the "refresh rate". Click on it and change it at the lower setting (about 60 - 70 Hertz). Click on aplly - OK. You will be back to the resolution settings page. Set the resolution at 1680X1050, apply - ok. Go back to "refresh rate" window and change the setting to a higher setting STEP BY STEP. In case of an "out of range" and blaack screen DON'T DO ANYTHING, at 15 seconds you will come back to the previous settings. With this procedure you will get the native resolution for your screen with the higher refresh rate.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
direct FixYa link:
Sep 07, 2010 | Samsung 226BW Monitor
1440x900 Monitor seems to think it is a 1680x1050 screen @ >19"?
Try reinstalling the video driver (Control Panel - System - Device Drivers - Video ... ) Good luck
Jun 13, 2009 | ViewSonic VA1930WM LCD Monitor
New monitor but unable to use its maximum resolution settings
no, there's nothing wrong with either your graphics card & monitor.. it just that your graphics card does not support a 1680x1050 resolution. if you want to fully enjoy the resolution of your monitor, you should upgrade your graphics card. purchase at least 256mb graphics card and you will see the difference..
Jan 21, 2008 | Gateway FPD2275W LCD Monitor
You could check your DPI setting in the display, being a large monitor your DPI setting shoul be up around the 75 - 85 Hertz.
To access this
Control Panel --> Display --> Settings --> Advanced --> Monitor and then click the drop down box and see what the DPI is set to and keep trying the different options until it is clear.
Hope this helps.
Dec 04, 2007 | Gateway GT4010 (RBGT4010) PC Desktop
use 1280 x .. range resolutions for 17" monitors and 800x ... range resolutions for 15' monitors . dont hear to recommended resolutions
Dec 04, 2007 | Gateway FPD2275W LCD Monitor
Movie on monitor
Hi, Normally I would suggest that you first lower your laptop's screen resolution, refresh rate and color quality and verify that you have enabled the external monitor or dual view in your Display Property Settings as well as the Fn key + F?. However, this kind of problem should not exist with an LCD Widescreen monitor with specs and features as your Samsung 226BW. If trying the reco on the first paragraph and you still have no movie display (but all other laptop display shows), perhaps it is a problem with the Samsung 226BW. To my knowledge, this particular brand/model uses no less than 3 different panel display, some not as good as the others. Verify that you have an original Samsung panel display in your Samsung monitor by looking at the sticker at the back of the screen, it should say Model: 226BW [R] S. If it says A or even a C, then perhaps the display panel is not living to its specs/claimed capacities. You of course can request a replacement from your dealer and cite your problem but insist that it be an "S". Most instances (but not always) an "S" would mean panel screen by Samsung, "A" by AU Optronics and "C" by CMO. Hope this be of some help/idea. Pls post back how things turned up or should you need further information. Good luck and kind regards.
Sep 23, 2007 | Samsung 226BW Monitor
Window screen problem
I'm guessing you may need to download the proper software and drivers for this monitor. Have you always had this problem and now want to change it? Try this website:
Jun 21, 2007 | Samsung SyncMaster 214T 21.3" LCD Monitor
ASUS P5VDC-MX Motherboard Logo
333 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
