HP HP Digital Sender 9100C Multifunction Printer p/n C1313A Fax Machines
Problem for HP HP Digital Sender 9100C Multifunction Printer p/n...
HP Color LaserJet 8550DN input device failure,
By june_goritz on Oct 23, 2009
HP Color LaserJet 8550DN input device failure, check cables and cycle power | error code: 66.01.02
Best Solution
posted on Oct 23, 2009
Very Helpful)
wheatlandsvc
Rank: Guru  Office Equipment  Expert
Rating: 92%, 104 votes
This error message indicates a lifter malfunction has occurred. When the 2000-sheet input tray (Tray 4) is closed, the paper deck lifts the paper stack until it is just below the feed rollers. Photosensor flag PS34, the paper surface photosensor, determines when the paper stack is lifted into the feed position. When PS34 does not detect paper in the expected time, the printer reports a 66 error. SOLUTION: Follow the steps below to troubleshoot and resolve the issue.
  1. Turn the printer off, open and close the tray, then turn the printer back on to see if the error clears.
  2. Open the drawer and check for extra paper or items stored on the left side of the tray. This will prevent the tray from lifting due to excess weight or blocking the lift of the tray.
  3. Remove all the paper from the tray. Remove the tray guides and reseat them. Verify the guides are not bent or broken.
  4. Lift the paper deck manually to verify there are no obstructions in the path.
  5. Pull the tray out as far as possible and observe the white bushing on the back right side of the tray. If the white bushing is broken, the tray will not lift properly.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for HP HP Digital Sender 9100C
Questions and Unsolved Problems for HP HP Digital Sender 9100C
Do you recommend HP HP Digital Sender 9100C Multifunction Printer p/n C1313A Fax Machines?
Answer
Answer
My HP 9100 all-in-one reports the following error - Scanner not responding, press? for help. Can you... (More)
Answer
We have 3 HP9100C digital senders with 2 machines working fine. On one, when sending scan to a user,... (More)
Answer
daily activity report which gives the detail of total number of copy/fax/prints/scan done in a day
Describe your Fax Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Fax Machine Experts
Top Copier & Fax Repairmen
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
