-   fully charged Philips CD445 cordless phone w/answering machine, however, handset keeps blinking "searching". Cannot do anything with the phone....i will go return it for another one.
I believe the problem might be that the handsets are not compatible with the phone base, since i had them replaced with handsets from another Philips phone box when i noticed that the original ones looked "used"/returned!-   mazeeka
Apr 28, 2009
-   Unable to register additional phone. Asked for "base number" which I cannot locate.-   Guest
Apr 28, 2009
-   unable to locate base number which is required to register additional phone. My unit is a Phillips CD 445 DECT 6.0-   Guest
Apr 28, 2009
-   Unable to find the number of my base unit which is required to register the product John H-   Guest
Jan 08, 2009
-   MY PHONE SAYS UNREGESTURED I CANNOT GET IT TO WORK CAN U PLEAS HELP
-   Guest
On the hand set: - menu button - ADVANCED SET - REGISTRATION - base 1 - pin # is 0000 (default)
On the base station and the base station handset - press and hold for at least (3) seconds, at the same time: - on base - the intercom button - on base handset - menu button
It's in the manual but you need a magnifying glass to read it.
What is an affordable corded phone with big buttons for an elderly with poor eye sight with an...
(More)
What is an affordable corded phone with big buttons for an elderly with poor eye sight with an answering machine and some memory buttons
i need a user manual for a panasonic telephone kx-tcd535 grm and kx-tca151 exm (in pdf format if...
(More)
I NEED A USER MANUAL FOR A PANASONIC TELEPHONE KX-TCD535 GRM AND KX-TCA151 EXM (in pdf format if possible)
I also have a cordless phone by Philips which has recently been stuck in a continuous search mode. It's able to receive calls, but there is no ring when calls come through, they go to the answering machine.
I have been able to register only the first and second base!
Comment by Guest, posted on Jan 04, 2008
i have recently purchased a phillips se445 cordless phone set (3) bases, i cannot register any phones with any bases fully charged batteries all handsets just keep flashing searching
