Question about RCA D52130 52" Rear Projection Television
Dark picture my picture is very dark if there is any light in the room you cant see the screen
  • kbb2002 Apr 04, 2008
    I have the same problem...if there was a bulletin does anyone have a link to it? I was also wondering if it could be a weak lamp?
  • forallthsin Dec 15, 2008
    my problem has been the tv won't power on, clicks...nothing, clicks more... nothing.  replaced the resistor at r14700, this one was burnt in half.  After i replaced it, tried to turn tv on again, and same thing happened, and resistor burns out again.  do you know what could be causing this to burn out?  only have 8 replacement resistors left so hopefully you know what's up.
  • 373 Answers
If you can find it inside the set you need to replace R14700. This is the location number written on one of the boards. It is a 27K resistor at 1/2 watt. There was a bulletin by RCA on this problem
Posted on Dec 30, 2007
Why is sony bravia dark screen
If your TV seems to be darker than you think it should be, it is possible that the problem is with the light sensor. The light sensor will automatically adjust the picture brightness based on the ambient light that is in the room, (i.e. if the room is bright the picture will also be bright, if it is dark the picture will also be dark).
To turn this feature off go to Settings > General Setup > Light Sensor.
Feb 27, 2015 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Tv picture fades in the dark
Menu - Picture - Energy Saving
Various settings including Off.
Sep 27, 2014 | LG Televison & Video
Green light stays on nd no sound or picture
use a very dark room where you cant see nothing. turn it on and tell me if there is any light on the screen "backlight"
Jan 08, 2014 | Hyundai ImageQuest HP4240 42 in. Plasma...
Black screen
If its LCD get the room very very dark and turn on--with a flashlight near the screen look closely at the screen to see if you see a very faint image of the picture or not---Most LCD flatscreen's (not Plasma) use what is called a back light to light the screen--light source.
If a faint picture can be seen that way the light is not on.
Dec 17, 2012 | Sceptre Televison & Video
No picture is your problem? No model number but a suggestion if a LCD set---in a very dark room look at the screen with a flashlight--see a faint image of any sort there?
Nov 07, 2012 | Televison & Video
Dark picture image, dosen't respond to briteness control
are you able to see the picture in a dark room ? does it appear bright enough then ? if so the lights behind your screen have dimmed or gone out completely. this may just be the power supply for the lights or your lcd panel may need to be replaced
Nov 19, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
White corners SONY KDL52XBR6
This is called a dark shading error. All the LCD consumer sets have some visible degree of this effect. Some will be a little less or more than others even from the same batch in the assembly run. This has to do with the optical design quality of how the back-plane lamps illuminate the screen. The design and assembly tollerance of this area is very critical.
Normally, LCD screens don't show their best picture in a darkened room. The very black regions of the picture content may look a little washed out. LCD screens are best watched in a room that is lit, but not very bright. You have to consider that there is a powerful set of lights behind the polarized panel of the LCD display, and there will always be some breakthrough of light.
If you want a TV that is more like a CRT in its characteristics a Plasma would have been a good choice. The trade-off with the Plasma is that it does not have the picture sharpness of the LCD. A Plasma set is best watched in a darkened room.
If you have an LCD computer monitor, take a look at it in a dark room with a black screen. You will most likely see the dark shading errors. Only the very expensive production studio type LCD monitors have less of this error than the consumer sets, and they are not absolutely perfect.
Jerry G.
Nov 19, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Projection TV when turned on picture is dark can view slight images until dinning room light is turned on
Try hooking the TV to a different outlet fed by a different breaker. Does the problem go away? If so, the culprit may be a wiring problem in your house that is causing the TV not to get enough power unless the dining room light is on.If in doubt, consult an electrician to make sure both the dining room light and TV outlet circuits are working properly.
Mar 06, 2008 | Mitsubishi WS-55613 55" Rear Projection...
RCA D52130 52" Rear Projection Television Logo
127 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
