Question about JVC RX-5020VBK Receiver
Blows fuse The receiver blew the main fuse during normal operation and now blows any replacement. I suspect the output transitors of one of the five amps are blown. I'd like to download a service manual which is available from a number of sites but am not sure which site is best. Any recommendation as to where to obtain the service manual and how to isolate which output stage may be bad? Oh yes, the device numbers are SK B1560 and SK D2390. Thanks!
  • stevewa Jan 27, 2008
    I have a similar problem with a JVC receiver; have you diagnosed, repaired or solved the problem yet?
I've got a problem on my denon receiver/amplifier. what devices are 1) KIA 7915PI 321,
2) SK B1560 44 P
3) SK D2390 43 Y
can you please send me some details about these devices (semiconductor, diode, integrated circuit, terminal voltage regulator, capacitor, etc.)
thanks in advance!
Posted on Jan 28, 2008
My GFA 555II amp blew the 2 left channel fuses while playing at normal loudness levels.
Fuses blow when there is a short circuit. All you need to do is replace the main output devices located on the heat sink. They are the ones that will have shorted most likely. Check your speakers and wiring for that channel. Any wire cross connecting will cause that kind of fault, likewise a faulty speaker.
Any engineer will be able to do this job, providing they can find the parts. But you can check them yourself by looking for the parts on the internet.
Mar 03, 2016 | Audio Players & Recorders
SONY RECEIVER MODEL STR - D315 keeps blowing a fuse
When the main fuse blows on a sony, it is usually caused by shorted output transistors. You would have to replace these transistors before the unit will not blow the fuse and power up correctly.
May 23, 2013 | Audio Players & Recorders
Whirlpool Microwave MH6700xW-0 Blows internal fuses regulary
Assuming your power line voltage is okay, it would not surprise me that after 27 years, your high voltage capacitor is drying out and increasing its capacitance. This will cause variance in the high voltage output, which can stress the magnetron and increase current consumption.
You can order Whirlpool parts my model number here.
For more free DIY and other help & advice, feel free to contact me via my site.
William E. Miller, AS-EET
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 16, 2017 | Whirlpool Microwave Ovens
Fuse keep blowing after crossing speaker wires.
Fuses blow when there is an overload. In your case when you crossed the speaker wires you shorted the main amp. This now has a part that is acting just like a strand of wire.
Trace back the channel you crossed the wires and find the main output device(s). Then replace them. They will be located on a heat sink if that helps.
Jul 03, 2017 | Sony MHC-MG510AV Shelf System
Hotpoint Dishwasher BF1620 blew the main fuse circuit in fuse box during mid cycle wash? Re-set main power fuse circuit but now as soon as Dishwasher switched on immediately blows main kitchen power fuse...
This is happening because you have a very bad fault, a Phase to Earth short, problem. Leave machine UNPLUGGED, Breaker/Fuses OUT. do NOT use it, nor Touch it, It is possible to get severe electric shock. PLEASE get a registered serviceman to inspect this unit.
Feb 07, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Internal fuse on cambridge a1 mk3 has blown and when replaced,blew instantly??
When the fuse blows suspect an overload in either the power supply or Main Amp section.
Check for burnt/damage parts first!
Power Supply faults that will blow the fuse are: Transformer, Rectifier, Voltage Regulator, Large Electrolytic Capictors, Diodes & any other semiconductor connected with it.
Main Power Amp faults are: any semiconductor device on the heatsink.
Jan 04, 2010 | Audio Players & Recorders
Blows main fuse when power is turned on
Shorted power supply/module is most likely problem.
May 27, 2009 | Sony STR-DE635 Receiver
27F522T RCA
Dec 06, 2007 | Televison & Video
Blowing Fuses
If you disconnect the speaker wires from the amp and the fuse blows only after the remote voltage is applied (when the head unit is switched on), the output transistors are likely shorted.
Nov 14, 2006 | Profile 600MSX Car Audio Amplifier
My tv power does not come on
This set uses a switching power supply. Usually when there is a short on the output side of the switching transformer the supply will just shut down and refuse to operate but normally will not blow a fuse. If the fuse blows suspect a problem with something shorted on the input side of the switching transformer such as I801 regulator IC, diode bridge D801,or other shorted component. Perhaps someone else could tell both of us any other part that could cause the regulator to blow and should also be replaced to prevent regulator failure in the future.
Jun 23, 2006 | Sylvania 6427TE 27" TV
JVC RX-5020VBK Receiver Logo
482 people viewed this question
Top JVC Audio Players & Recorders Experts
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
