The dishwasher will not stay running. It seems to have a sweet spot located just below the control panel that if I apply a small amount of pressure with the palm of hand, it will start to run....but then when I remove the pressure, it shuts off. Have cleaned the rubber gasket around the door....any ideas. It worked just fine the other day. I do not have children or pets who may have rested on the door so I can't imagine what changed overnight.
SOURCE: G843SCVI Dishwasher
I am a authorized Miele Service tech - we can supply you with any parts you need - just give us a description and your model number / serial number
Thanks
[email protected]
SOURCE: Door has small leak. Needs new gasket around the
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
SOURCE: Miele Dishwasher - Not cleaning
Hi, I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
xxz
SOURCE: Drain pump runs non-stop. Continues when dial is
sounds like the flood switch has activated.
You will have to drag the dishwasher out from under the counter after turning off the power to it. Tilt to one side so that any water collected under it is expelled. This will free up the flood switch. Wait about 30 minutes and turn the power back on.
There could be a leak of some sorts from the door seal or hoses which is causing the water to collect.
Hope this solves the problem. It is unclear why none of the lights are lighting up to show a fault condition.
