Maytag topload washing machine
My washing machine will not longer agitate cycle. It fills the tub up with water and will not turn off,causing an overflow, but will spin cycle and rinse cycle following the washing cycle, which will no longer agitate or wash. Before this happened, the load of towels was unevenly distributed and the tub knocked and rocked for a few minutes until I opened the lid to remove and reorganize the wash load/ Can this be fixed or will I need a new washing machine.
    President:
  • 1,314 Answers
Either you have a bad pressure switch or the latex hose to it or has a hole in it it may have come off either the tub or the switch if it was shaking badly it will be connected to the fill option switch on the control panel go down then hook to tub
Posted on Dec 30, 2007
Washer wont pump water unless in spin cycle
it is not supposed to pump water unless it is in the spin cycle. On most topload washers the motor turns one way for the agitate cycle and then the motor reverses during the spin/rinse cycle which in turn reverses the pump and causes it to pump the water out.
Oct 28, 2010 | Maytag PAV5157A Top Load Washer
My maytag topload washer overfilled,
It isn't a sensor problem, it sounds more like your water level tube has pulled loose. This is attached to the outer drum itself. You can see it when you remove your front cover to the right of the outer tub. This tube uses the pressure generated from your tub water level to push air up to your water level selector, which has a rubber membrane that flexes and closes 2 contacts as the water level makes the rubber expand. If that tube is off, the water will just keep running.
Mar 18, 2010 | Maytag MAV3905EWW 13 Cycle Washer
Quite old admiral mega 22 plus topload washer. the machine did not agitate after filling up. I tried various points on the 3 cycle types and it did not spin either. My son tried moving the agitator and...
Yes sounds like you have now disturbed the seal and will need a new one, remove the agitator and inner drum to get at the seals, to remove the agitator pull off the softner cap and remove bolt form down inside.
To remove the inner drum, the top part of the washer needs to be hinged back to gain access, to do this insert a flat balde 4" from each side at the seam with the front panel to release the clips, lid will now hinge back to give access to the drums, on the outer dum there are clips all the way round to remove the top section of the outer drum release these. remove the bolts under agitator to remove the inner drum. you should have access to the seals but it has been a while.
Reason for not agitating in first place is probably the water level switch at the rear of the drum with a small 8mm hose connecting it to the drum.
Dec 29, 2009 | Admiral AW22 Top Load Washer
Washer won't agitate
Check your timer and make sure that it is working correctly with a multi meter
Feb 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
10yr whirlpool toploader wash machine no spin/agitat. but works?
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 08, 2009 | Whirlpool Washing Machines
Washing machine fills, but won't agitate
Lid switch if its a Maytag Alantis... You said you have a GE top load in the start of your problem and ended witha maytag?
Dec 18, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer
This is similar to a problem I had after my power suddenly went out while the washer was filling with water. When the power resumed the washer would no longer run water... all other systems (agitate, drain, spin) worked fine.
A 10 minute, $113 dollar service call revealed that there was a fuse inside the front upper left area that had blown. Remove the 2 screws at the bottom of the front panel to get access to the inside.
Check it out and replace it if necessary.
Jan 20, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag top load washer leak
underneath the agitator is a graphite seal ring and nut that seals the inner tub and the outer tub. a suitable spanner wrench or a 6 inch channel lock plier will remove this locknut. replace the seal.
Sep 02, 2007 | Washing Machines
Washing Machines Logo
218 people viewed this question
Top Washing Machines Experts
