Question about GE 25932 Twin Cordless Phone
How to insert a # sign after the memory number
Hi. I am trying to program numbers into the phone's memory. I know how to do the name and number, but need to add a # sign to the end of the string of numbers. Since the # sign is a P (pause), how do I insert a #?
Thanks, Jill
  • Anonymous Apr 09, 2008
    how do i program numbers into the phone?
  • 48 Answers
Phones are a bit odd in this case. They key layout changes a bit when you are entering text into the phone, rather than dialing a number outside of a menu. Look carefully at the keys, there is a button that give you access to symbols, it will be labeled so in the same text and color the pause letters are. What i mean is there are the numbers and letters on the surface of the button, but what you want to pay attention to is the secondary letting etched on the bezel between the buttons. Hopefully you will easy find it. I can reference it if you send the model number to my email address or update your question.
Posted on Jan 07, 2008
How would I program a number into this phone?
This is the way to program the numbers
  • 1.Lift the handset and press PROG button.
  • 2. Enter a phone number as you would dial it.
  • 3. Press PROG again and then press the corresponding memory button to store this number. Hang up immediately.
  • 4. The number is now stored into memory. The memory button in the lower right corner of the frame can be programmed for emergencies. Whenever the handset is lifted, a light will guide you to that button.
  • Note: Press the REDIAL button to insert a pause in the numbers you are.
Pleas this link, for the phone user manual
May 18, 2011 | Ultratec CrystalTone Corded Phone
I need to know how to take out unwanted phone number and name and program in a new name and phone number. Lost my manual and can't seem to upload yours on my computer.
removing and installing phone numbers isn't hard. Just hold MEM small button down for about 5 seconds then use up or down arrow to arrive at stored number. Then hit select, & follow prompts (edit Memory #, delete Memory #, or go back). The rest you should be able to do.
Aug 27, 2010 | Uniden Cordless Phone exai398i
Sir when I am dailling my numbers are not recorded
HI there,
For clarification of your problem, may I know what exactly the phone model that you have.
Did you mean that only number and not the name of your contact appeared on the screen or into your call registry?
In some cases like this, it just happen that you have eventually has done a double entry of the number on your phone book or into your cellphone. If you have entered or save 2 or more names on one number, the unit will only display the number and not the name assigned to it, because it will not display multiple name on one same number.
Also check if your contact was saved into the phone memory or into the SIM memory. Check the phone book settings and check the memory in use, by default choose >>Phone - SIM memory, to use both locations.
Please kindly let me know, and hope to hear more info soon.
Thank you for using fixya.
Jun 22, 2010 | Cell Phones
My n97 would not come on. I am charging the phone
The program of your phone is damage it needs to reprogram.. To reproram your phone just remove the simcard and memory card.. Then press respectively the Call Sign, * Sign and number 3 of the keypad. And press the power button by holding those keys i mentioned. When you see the installation progress just wait until they finished before you unhold those keys. After that insert back the sim and the memory and try to on it back if it works.
Oct 20, 2009 | Nokia N97 Cell Phone
After many years have misplaced the instruction manual for our Vista 200. Need to know how to set up names and numbers for the automatic dialling feature.
First, ensure the display is bright enough. If it is not, press successively on the "Brightness key" that is located on the top of the phone above the "Memory key". You have 8 brightness settings. Note that the "Brightness key" has no label.
You are now ready to start programming.
1. Press the "Memory key". It is labelled "Memory" and is located above the "Memory keys" numbered 1 to 10 on the right-hand side of the phone.
2. Press the "Memory key" you want to program. (1 to 10)
3. Enter the number you want to program using the "Dialling keys"
1, 2, 3,
4, 5, 6,
7, 8, 9,
*, 0, #
4. Once the phone number is entered, press the "Memory key" again.
5. Now enter the "Name" for the phone number you just entered. To do this, you press the "Dialling keys" as follows:
For A press the "2" key once,
For B press the "2" key 2 times,
For C press the "2" key 2 times,
For Q press the "7" key 2 times,
For Z press the "9" key 4 times.
Use the same for all letters.
To go to the next letter, press the "Right arrow key".
For a space, press the "Right arrow key".
6. Once the name is entered, press the "Memory key" one last time. You are done.
7. To test it, press the "Memory key" you just programmed.
Oct 19, 2009 | Bell BE-412CID Corded Phone
Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Nov 28, 2008 | Panasonic KX-T7730 Corded Phone
I lost my manual and I need to know how to program a name and number
I just programmed my phone of the same exact model, I was searching on Google for a solution so I thought I'd share it with you. GE does not have a manual on their website for that model, but I went to the manual of a similar model (27940DC1) that has a manual, . The procedure is exactly the same. I was able to program my new voicemail number in with no problem. Good luck!
Feb 12, 2008 | Cell Phones
Programming instructions for used phone
Program Thomson Consumer Electronics (GE?) 2-9316A Speaker Phone (what we found works)
To program:
1. press speaker or lift handset.
2. press STORE
3. dial the number to be stored
4. press MEMORY DIAL
5. press location (0-9 on keypad or 1 of the 3 emergency quick dial)
6. press speaker or hangup.
To dial emergency numbers:
2. press any of 3 emergency quick dial
To dial stored numbers:
2. press MEMORY DIAL
3. press location (0-9 on keypad)
Does anyone know how to add PAUSE in a stored dial string?
Aug 27, 2007 | GE Corded Speakerphone with 2 Cordless...
Cordless phone
Hi Dont know if this applies to your phone but if there is a button that says memory try pressing it .If your phone does have this feature a blank will probably come up.Try then pressing a number button (example # 1) .If there is no info in that slot try pressing the momory button again.It should ask for a name.After you enter the name press the Memory button again it should ask for a numer.After entering the nubmer press memory again.This should save the persons name and number. Now to get back to this info press memory and the corresponding button # you saved it on.
(tip, press the "talk" or "call" button while that persons info is displaid to call that persons #)
Aug 20, 2007 | Uniden Cordless Phone
GE 25932 Twin Cordless Phone Logo
297 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
