Canon PIXMA iP2000 InkJet Printer
Problem for Canon PIXMA iP2000 InkJet Printer
The message 'waste ink absorber' nearly full
By eblac on Oct 23, 2009
The message 'waste ink absorber' nearly full appears when I try to print from my Canon Pixma iP2000 printer
Solution #1
posted on Oct 27, 2009
Not Rated)
nethload
Rank: Master
Rating: 76%, 11 votes
solution found!!
> this is copy paste from some other message and it works
> and for now it's not only temporary.
> I have a temporary fix (doesn't keep without power):
> 1:Unplug power and USB
> 2 Open door and hold power button.
> 3: Connect power.
> 4: Close door, then release power button
> Connect USB and an press power to use.
> Print instructions and stick it to your printer
Was this helpful?
Yes
No
Solution #2
posted on Oct 23, 2009
Not Rated)
imagifix
Rank: Guru  Computer Hardware  Expert
Rating: 90%, 23 votes
Hi
Unless you are complelty happy taking items like this apart i would suggest taking it to a local qualified computer shop or repair centre. The waste tank or absorber is a collection of all the waste ink that has ever occured when cleaning the printheads or even charging cartridges when its had new cartridges fitted.
Unfortunetly it is rarely just a case of replacing the pads or tank but also normally requires the system to be reset to prevent the printer halting altogether.
Thanks
Taz
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA iP2000 InkJet
Questions and Unsolved Problems for Canon PIXMA iP2000 InkJet
Do you recommend Canon PIXMA iP2000 InkJet Printer?
Answer
Answer
Printer asks to install the head. I removed the head & put it back, I also unplugged the... (More)
Answer
Power light keeps flashing red and then orange. The middle cartridge holder under the top lid when... (More)
Answer
i have replaced both ink cartridges in my cannon pixma ip 2000 but it will not print colour only... (More)
Answer
ip 2000 on button flashes green then orange , wont operate !
Answer
The power button has just stopped functioning. It does not stay on when pressed.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PIXMA iP2000 InkJet...:
Top Printer Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
