Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
Dacor range erd 48
Initially had beepine with error code f0 then went to f1, turned off circuit breaker and now have 050 075 error codes
    Genius:
  • 1,665 Answers
Dacor model ersd30 how do i fix an F0 error code that also blinks F1 and beeps
Hi dan8260,
If you're encountering F0 error code, it is due to a stuck function key. You need to replace the touch pad to fix this error. If the touch pad is part of the clock, you need to replace the clock or ERC.
Hope it helps.
Thank you for using FixYa.
Feb 07, 2011 | Dacor Epicure EO127 Stainless Steel Dual...
I need Please a solution to F1 Error Code on GE/Kenmore electric ovens Model # 911.4658815 Thanks E-mail: elylimo@gmail.com I have the same model number. 9114658811 and plugged in the stove for the...
To my understanding error code F1 would indicate a faulty control board, possibly thermistor control. The only recourse is to have this replaced.
This of course would require a fair familiarity of electrical/electronic components/circuitry and safety procedures, use of a DVM and possibly a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 13, 2008 | Kenmore 46123 Stainless Steel Electric...
Dacor oven code FO means keypad is in depressed mode.....and then what?
Hi john56584,
The "F0" error code description is a stock function key. Here are basic test that will help you to determine if the ERC or touchpad is defective.
1. Unplug the range power cord or turn the power off to the range at the circuit breaker.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the code comes back.
7. If F0 comes back, replace the ERC. If it does not, replace the touch pad.
Hope it helps.
Sep 01, 2010 | Dacor Preference RSD30 Gas Kitchen Range
GE Profile Performance Spectra Range error code F0
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jun 20, 2009 | GE JKS05 Electric Single Oven
Timer tone goes off with F1 display
Hi arl3933,
The "F1" error code description is a System Watchdog Circuit. Please press "CANCEL", if beeping continues after 30 seconds, please check the main control board(ERC). Here are basic test that will help you to determine if the ERC or touchpad is defective.
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope it helps.
May 14, 2009 | Dacor Preference RSD30 Gas Kitchen Range
F2e0 error on stove
Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
My kenmore electronic stove is having a beep with code F1 on the
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Caloric gas range problem
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Dec 24, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven Failure Code F1
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection.
to fix your F1 error
92028 RELAY PCB, 105 C
Nov 20, 2007 | Dacor Preference RSD30 Gas Kitchen Range
Error codes on my Dacor Range -
Both of those codes suggest a bad membrane switch assembly. i dont specifically remember what the f1 error is, but the f0 error is "stuck membrane button" The membrane switch is just the touch panel, and usually run in the mid $200 range for the part. Its fairly easy to change, just label all your wires when you pull em off so you know what direction they go in. some of the connectors CAN BE put on backwards, so just make a good diagram or whatever to get em right. Good luck!
Jun 17, 2007 | Dacor ECS130 Epicure Electric Single Oven
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
790 people viewed this question
Top Dacor Kitchen Ranges Experts
Steve Allison
Steve Allison
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
