Question about Dryers
The dryer knob won't start the dryer
The knob for my Frigidaire Gallery Dryer will not work to start the dryer. We were able to take to plastic timer knob off and tried to start the dryer by using a pair of plyers but that did'nt work.
  • 5 more comments
  • Carolyn Fischer
    Carolyn Fischer Dec 30, 2007
    The knob turns but only I hear it rachet in between each setting. There is a black ring that came off which is supposed to fit over the inside plastic part of the knob but I can't put it back on. Any suggestions. thanks
  • Carolyn Fischer
    I switched off the breaker and then on again and tried the dryer. When I try to start the dryer by pulling the knob, the knob just comes off. Also, the washer works which is right next to the dryer. I appreciate your suggestions.
  • Carolyn Fischer
    On this old dryer- probably at least 8 years old, you pull the knob to start it. The knob let's you select the cycle and then you pull it to start it. There is no start button.
  • Carolyn Fischer
    I feel like a complete fool. I was going by what my tenant was telling me and I think he was thinking the dryer worked like the washer. So now he found the start button and it works! Sorry for taking up your time but I appreciate you helping me!
  • caseybmalone May 03, 2009
    i can turn the knob on the dryer and i hear the timer start, but the knob pulls off when i try to pull the knob to start it. i tried using pliers...no luck.
  • Anonymous Mar 23, 2014
    timer does not work, knob sit in one place while dryer is running
  • Anonymous Mar 28, 2014
    Knob and start button broken off
    Welcome Back:
    Visited the website for 2 consecutive days.
My knob is stuck and will not pull out, if i can get it to pull out it would work, i don't know if the timer is gone or what
Posted on Feb 02, 2009
    President:
  • 1,314 Answers
Does it turn and can you hear it ratchet as it turns
Posted on Dec 30, 2007
  • 3 more comments
  • robert samples Dec 30, 2007
    the ring goes inside the knob not out it reinforces the knob on the inside turn your breaker off then on see if it starts i beleive you may have a power promblem push the ring inside the knob matching the flat part then put it on timer shaft
    they are not on the same circet you dont start the drier by pulling on the knob you push the start button
    its not a frigidare then ive worked for the frigidare factory for 15 years always had a start button little round button that says start
    what is the model number
    I'm so glad I could help you thank you for your time please see TECH17 should you have anymore problems i will be more than glad to help.
My Frigidaire dryer does not work. It seems like it does not register that the timer is being turned back. It is the Gallery Series, Model GCET1031FS2.
Thank you for your inquiry, Ashley!
From what you have described your Frigidaire dryer is not working and it seems that the timer is not registering. This sounds like you may need to replace your timer or you could have a faulty wiring harness. In order to accurately diagnose your dryer I would recommend having a professional technician out. They will be able to properly disassemble your dryer and test each electrical component. This will help you avoid any unnecessary part purchases. Best of luck! -Matt
May 28, 2015 | Frigidaire Dryers
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
My frigidaire gallery electric dryer won't turn on. In the past it has been a bit on the noisy sound with a squeaky sound coming from the back. The last time I went to put a load in the dryer the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 27, 2011 | Frigidaire Dryers
Frigidaire gallery series electric dryer/washer. Dryer won't start
heatman101
Aug 10, 2011 | Frigidaire Dryers
I have a Frigidaire Gallery electric dryer model no. GLEQ642CAS2 that will not start when turning start selector knob. Problem is intermittent. I've tried pressing on the door in various positions...
heatman101
Aug 09, 2011 | Frigidaire Dryers
I have a stackable Frigidaire Gallery Dryer. It won't turn on...
turn the start and it's like the drum gets stuck. then starts smelling like burning.
Mar 05, 2010 | Frigidaire Dryers
The timer on my dryer isn't working properly
HI. the timer motor is damaged at this point. The Auto sector is dead. This is not a serviceable part, and you will need to replace the entire timer mechanism to correct this issue.
Oct 02, 2009 | Frigidaire Dryers
Frigidaire Dryer (electric) wont start
it could be the door switch or the control timer .
Oct 19, 2017 | Frigidaire AEQ6000ES Electric Dryer
Dryers Logo
723 people viewed this question
Top Dryers Experts
