Question about Panasonic PT-47WX49 47" Rear Projection Television
Panasonic PT-51G50CU This rear projection TV is 10 years old. It was perodically switching itself off and on during viewing and now there is no sound or picture. When we turn it on there is a flubbing noise from the speakers and there appears to be a clicking sound from the power board.
  • 6 more comments
  • foup Jan 01, 2008
    I' m confused. Is it a cicuit board problem or a safety switch/lamp cover issue. Are we talking about the same set PT-51G50...because I don' t know what lamp cover that you are referring to with one screw. There is a large back cover with multiple screws and a smaller hard board covering the chassis
  • foup Jan 02, 2008
    I have searched everywhere for this lamp at the power cord entrance, plus I cannot locate a fan anywhere. Again, are we talking about the same TV? This is not a plasma set.
    In any case, if this switch was open, why is there a clicking and "flubbing" sound coming from the set?....Thanks
  • foup Jan 02, 2008
    I' m sorry..I went through the instruction manual and the service manual including the 28 pages of the parts list and there is no mention of a fan or lamp. I don' t know if it helps, but the chassis number is AEDP810 and there are 3 CRTs.
  • foup Jan 02, 2008
    Do you have more to say...this is the last line I was able to view
    "Just check the convergence circuit once..."
    Based on your experience, is this a cold solder joint or component short?...Thanks
  • foup Jan 03, 2008
    Hi...I already have the whole chassis out and was looking for blown components. The only obvious thing thst I could find was at A19 where there looks like a component is missing on the bottom of the board. There is a silicon imprint...maybe a cap, but I was unable to find any loose parts after I removed the chassis. There is another cap?... also siliconed to the bottom ajacent to it marked "B 121". What is the component that you had in mind for the convergence board?
  • foup Jan 08, 2008
    Hello, I did some more checking into this imprint and was unable to find any broken leads to any component in the vincinity.
    It may be a mistake at the time of assembly.
    Do you have any more details as to a possible component failure or the source of the problem?...Thanks
  • foup Jan 10, 2008
    I need a second opinion on my problem. It appears that we have hit a roadblock....Thanks
  • foup Jan 10, 2008
    Thanks for the quick response. I checked through the service manual and the instruction manual, but there is no reference to the SSB. Can you be more specific..part number, location
    Guru:
  • 1,894 Answers
Sounds like a bad SSB module(small signal board)
Posted on Jan 10, 2008
  • dewan nafees ahmed Jan 10, 2008
    am not sure about my last post. but this post will speak of your problem
    The clicking sound is the power ON/OFF relay being pulsed by the
    protection circuit. So, the set is going into protection for some
    reason. This circuit is monitoring current draw from what might be
    shorted circuits somewhere in the set. When detected it shuts the power
    relay OFF.
    That should get you started.
    i already said you not to consider about my previous post.
    by recent post tells you what is happening in there.
    "The clicking sound is the power ON/OFF relay being pulsed by the
    relay OFF.""
    so you are seeing the board in front of you. so you can only see the problem. try to locate it yourself. else call some tech who can see it for you and locate that faulty place.
  • 790 Answers
HEY !!
ITS A CIRCUIT BOARD PROBLEM ... IC MAY HAVE BLOWN OFF ...
Posted on Jan 01, 2008
  • 4 more comments
  • Kanth raj
    Kanth raj Jan 01, 2008
    try removing and re-installing the lamp cover on the back.
    may be the lamp cover
    is not seated properly causing the safety switch to not engage all the
    way, when the lamp cover heats up and expands, it fall away further
    from the switch tripping it, shutting the set down.
    when you remove
    and re-install the lamp cover, after you take the single screw out,
    tilt the cover out and forward from the top about 3/4 of the way out
    and then tilt it back into normal position and put the screw back.
  • Kanth raj
    ITS A VERY COMMON PROBLEM!! JUST CHECK THIS LINK HOW MANY PANASONIC USERS HAVE THE PROBLEM
    http://stafford.typepad.com/the_next_ame...
  • Kanth raj
    Kanth raj Jan 02, 2008
    lamp is in the small door in the rear on the t.v, just to the right and
    up a little from the fan secured with 2 screws...its where the cord to
    plug the t.v. in comes out.
  • Kanth raj
    please check the manual for the lamp cover ... ya of course am talking about the tv ... am trying to solve the display problem ...
  • Kanth raj
    Am very sorry i dint notice that its ten year old ... ya am talkin about the new one ... the mother board of ur model is no more manufacture of panasonic...there must be a short on the circuit ... if u r good at doing risky job u can open it and have a look .. Just check the convergence circuit once...
  • Kanth raj
    Kanth raj Jan 03, 2008
    Hey its may be a component short .. i totally doubt on the convergence circuit ... i think the problem is in this circuit which u gotta replace .. And that circuit wont cost u much also either .. Its around 10$... And by the way u alone open the circuit or u going to call the technician ??? reply
Why does my tv keep turning itself off
The tv projection lamp,might require replacing?Tv projection lamp inside this tv like 1 1/2 or 2 years already and tv daily used,like 4 or 5 hrs viewing of the tv?Yes,than projection lamp is the problems and the causes.The tv projection lamp require replacing.
Feb 25, 2011 | Panasonic PT-50LC13 50" Rear Projection...
My 10 year old tv goes off after about 5 minutes and the blue
Any colors mis alignments R,G,B.The tv have a problems known as convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced in the tv convergence board to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 17, 2010 | Panasonic PT-56WXF95 56" Rear Projection...
Panasonic rear-projection tv with no picture
sounds like a high voltage problem (flyback transformer) best thing to do is have a tech look into it, can be dangerous. Julio milleniumtvsvc@gmail.com
Jul 16, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic T.V. model number PT-47WX42F no picture or sound
R800 open on power board next to the relay.the resistor value is1.5 ohms 10 watt resistor.
Jul 15, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Power issue
No picture on my Magnavox Big TV RJ8530 S/N 61998120
Aug 06, 2008 | Panasonic PT-51HX42 51" Rear Projection...
Panasonic projection
Hello joselrivera1,
You have 2 defective Chip.
Part number: STK392-010
List price $10 each
Best regards
circuitcity
Jun 22, 2008 | Panasonic PT-51HX40 51" Rear Projection...
Panasonic projection tv
call panasonic, bulb blown under warranty for 18 months the bulb is 284.00 just had mine replaced. it's a little over a year old
Dec 27, 2007 | Panasonic PT-61LCX65 61" Rear Projection...
Dead tv
Sounds like a power supply problem. I am sure that the pop is the fuse blown. If the fuse is blown, this means that there is a short somewhere. Rear projection TV are like LCD projectors. And all of them use Switch mode power supply. If you are lucky, there is a chance that a protection device (like a varistor) is sorted. This means that removing this, even without replacing will bring your TV to life, however... Most probably the power supply is defective.
May 22, 2007 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
76 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
