Blue line across panasonic large screen hdtv
There is a blue line (arched) going across our panasonic large screen hdtv. What do we need to do to fix it? The TV is barely 4 yearls old....Thanks.
  • PattiL500 Dec 01, 2008
    I have the same problem...how can we fix it...
  • jrjbyoung Jan 09, 2009
    I also have the same problem, does anyone know how to fix it?
  • 8,617 Answers
What is the model number of your set?
Posted on Jan 13, 2008
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Hello I have several (7) blue lines in an arch pattern spanning across the entire screen. Mostly noticeable in dark to black scenes. Was wondering if anyone knows what causes this and if there is a way I...
The Blue CRT ( Picture Tube ) has a short. You may be able to do a temp fix by turning down the Blue CRT drive level ( Located behind the front speaker grille )untill the lines disappear. But its only a temp fix. The Blue CRT will most likely need replacement.
Nov 04, 2010 | Sony KP-51WS500 51" Rear Projection...
I have blue arched lines and blue screen
HI:
Your problem is the blue CRT or picture has gone bad, you will need to have the picture replaced, there are three tubes in this model rear projection television. Red, Green, and Blue. Replaceing the blue tube is the only option for normal operation to resume. It may be hard to find the tube, but you can try contacting this website for the part www.vdc.com, they manufacture and usually have stocks of sony picture tubes and rebuilt ones as well. The company's name is Video Display Corporation...
Jul 14, 2010 | Sony KP-57WV600 57" Rear Projection...
KP57WV700 - Blue Lines Across The Screen
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 26, 2009 | Sony KP-57WV700 57" Rear Projection HDTV
Arch in color on Panasonic
hello sound like convergance chips also check resistors and capacitors hope you get it fixed
shaun
Jul 31, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Arched blue lines across screen of Sony 63" Rear Projection TV
Had this problem bout 2,3 years ago...it was fixed in about 5 minutes with the help of this article
Tonight I have to do this fix again..the blue lines came back about a week.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
I strongly urge you to save the web page locally on your hard drive or print it out and place with the tv manual....
Good Luck..
Jan 05, 2009 | Sony KP-EF61 61" Rear Projection...
Convergence
if the blue lines runs across the screen in the center its a vertical deflection problem it will need to be diagnosed.
Oct 02, 2008 | Samsung HC-P4752W 47" Rear Projection...
Screen shadowing with colored lines
This is most likely a convergence problemand can easily be fixed. If you can solder you can repair this yourself. First try resoldering the pins on the convergence ICs. If that failes to resolve the problem, replace the ICs. THese are large black Ics attached to a heatsink and may be marked STKxxx.
Keep us posted.
Dan
Jun 27, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Showing black screen with a blue line
Is the blue line running straight across the middle of your screen? If so its a vertical deflection problem. Possible bad Vertical output IC
Feb 20, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Blue lines across screen sony tv
blown fues on the G board, that should fix my problem
and or might need to replace stk392 convergance amp ic's
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 05, 2007 | Sony KP-46WT500 46" Rear Projection...
Televison & Video Logo
284 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
