Question about SanDisk Sansa c140 MP3 Player
Sandisk c140 - Not showing mp3 when connected to the USB
I used the software provided by Sandisk to upload and sync up songs...It was working fine..Later I lost the CD and I'm not able to see the mp3 when I connect it to my USB..I cannot delete them since they aren't visibile to the file system...
Maybe formatting can help but is there any way around to get those songs back to my PC...I don't want to format.
Help me in this.
Thanks
  • bvisvana Dec 31, 2007
    I found a solution...set the mode to autodetect and plug the player...Vista has all the necessry device drivers and it showed me the files..
  • Anonymous Jan 08, 2008
    I'm having the same problem but I am running winXP. Any solutions?
I you open up the files musi cor what ever you stoted your files to yo should be able just klik on the left buton on the mouse and hit send to .... and just pick the destination on your pc that you want it to go to.
hope this helps
Posted on Dec 31, 2007
I dont have sandisk driver for my sansa E260..i cant transfer songs..
Sansa Not Recognized: Try connecting it to the back of your computer or another computer the back straight to the motherboard this should be USB 2.0 and see if it will recognize it as sansa or Drive/removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansas firmware and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier. Make sure USB mode is MSC
Recovery Mode may also allow your computer to recognize the sansa
lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software when finished disconnect.... Sync to upload songs to the sansa......Hope this works
Dec 01, 2010 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa c140 MP3 stuck at one song - please help!!
You might have to hold the power button down for like 20-25 seconds and if that doesnt work what I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Apr 07, 2008 | SanDisk Sansa c140 MP3 Player
Deleting
Does the player show up as a disk drive when you connect it to the USB drive of the PC. If so, you should be able use Windows explorer (assuming it's a Windows PC) to access the player like you would any other drive, find and find and delete the files.
Jan 21, 2008 | SanDisk Sansa c140 MP3 Player
My MP3 player won't updoad music
you got to go to my computer and look for device and click on it"explor it" find files and right clik to delete. my problems are it will never connect to pc for charging.. i see me taking it back real soon... after all it was a beta
Nov 18, 2007 | SanDisk Sansa c140 MP3 Player
Sansa c140 screen frozen
Try a "hard reset". Press and hold the power button for 15 seconds to shut off. With the device off, press and hold the vol + and the center select button. Power it back on, see if that works. You can add to the question if you have more questions. Best of Luck.
Sep 27, 2007 | SanDisk Sansa c140 MP3 Player
Frozen screen
recovery mode. slide the hold switxh so that is is redish hold record keep holding record and plug into computer.
Sep 26, 2007 | SanDisk Sansa c140 MP3 Player
Sync problem
I have a quick and painless solution for you.
First open your mp3 player and go to settings. Under the USB menu change it to MSC. Then plug in the mp3 player to the computer. Open the My Computer on your desktop, right click on the Sansa mp3 player and click Format. Make sure Fat32 is checked and Quick format is UNchecked. Then format the mp3 player. After that it should be clean and work just like a USB drive.
Hope this helps!
Aug 24, 2007 | SanDisk Sansa c140 MP3 Player
I got an error message and now my MP3 player won't turn on.
For Sansa or Sandisk problems, contact http://www.sansacommunity.com/ This site is dedicated to Sandisk products and can help you. Good Luck
Mar 22, 2007 | SanDisk Sansa c140 MP3 Player
Synchroniz
Hope this helps!
Jan 26, 2007 | SanDisk Sansa c140 MP3 Player
Need help
If you change USB protocols to MSC, it won't let you view the songs you put on using the Auto-Detect protocol, in my experience, and you can't switch back protocols. Reformatting by going into my computer, right clicking your sansa device, and then going to format seems to be the only way to get rid of these invisible songs, and you won't be able to select which ones. It gets rid of all of them, but at least they're gone.
Aug 11, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa c140 MP3 Player Logo
94 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
