Question about Samsung SyncMaster 205BW LCD Monitor
Help with my monitor
My monitor takes a long time to turn on. when i turn my computer on and my monitor the monitor usually has a black screen for around 15-30 mins. is it possible to fix this problem? if yes how do i fic it
  • brown1116 Mar 10, 2008
    my monitor is an hp pavilion mx75 it also takes along time to come on after the computer is on.
  • 372 Answers
Hi .
If your monitor has a transformered type power supply EG 12 TO 24 VOLTS try another one they have a nasty habit of going faulty on nearly all makes that use this set up.
If its not that then it could be the inverter that has gone faulty.
http://dysonmanuals.llc.nu/
Chris..
Posted on Dec 30, 2007
MAG innovision LT-926W 900W problem! After I turn on my computer, the screen immediately begins to flash and then goes black. The power is still on thought and so is my computer. If I take a flash light...
this means your power inverter inside the monitor is dead. This little gizmo lights up the monitor backlight. They dont fail all at once, but slowly die and give problems like you describe, you can order these online for your monitor , or find one on ebay for under 30 dollars, but unfortunately there is no fix, other than replacing the inverter. sorry. Please use the thumbs up rating if you find my answer helpful, albeit bad news. Take care. .
Aug 26, 2010 | Mag Innovision LT576s 15" Flat Panel LCD...
No picture screen black
un plug the monitor cables power cord everything turn off the computer the reconnect everything power back up turn on the monitor should work then
Feb 06, 2010 | Dell E173FP 17" LCD Monitor
My acer AL2416w monitor turns on to a black screen
I have 2 Acer AL2416W monitors that i have been using for 2 years. There has been a handful of times i would turn my computer on in the morning and the screen would be black and Acer would lightly flash on the monitor 1 time. Typically a restart would take care of the problem. Last week the monitor blacked out and i can't get it to work. Any suggestions?? I switched ports on the computer to verify it wasn't the video card and tried new DVI cables to verify it wasn't those? Is this fixable??
Sep 06, 2009 | AcerView 77E 17" CRT Monitor
My Dell E193FP boots up with the computer and then
Seems to be a very common problem with this screen. Im taking one apart as we speak to try to discover the problem. In the mean time - check that the Power Input isnt loose, and you can wiggle it around. Usually means the power is arcing onto the board
Sep 01, 2009 | Dell E193FP 19" LCD Monitor
Monitor flickers then goes to black/blank screen.
have you tested it for gone conponments
Aug 14, 2009 | Computers & Internet
Screen goes black after a few seconds
Problems like these happen all the time with LCD monitors. Usually one of two things. Bad Capacitors or a bad backlight. To check this, take a flashlight and point at your monitor (usually at a high angle) and see if you can still see the desktop faintly. If so then its either the back light or capacitor. Backlights shouldnt need replaced too often as they have a extremely long lifespan. Capacitors are relatively cheap and easy to replace, all is required is a soldering iron and an inexpensive trip to a Radio Shack. Though this isnt your monitor, it is a very good tutorial on how to go about replacing the capacitors.http://www.wizardanswers.com/liquidvideorepair.html If it is the backlight, here is another tutorial for that :D http://www.inventgeek.com/Projects/shorts/lcdfix.aspx
Jun 12, 2009 | Proview PL913B 19" Flat Panel LCD Monitor
Screen turned black
your monitor got a hardware problem:
1) the LVDS controler board out of work, only change or repair it could be fixed.
2) if you can see some show like smaller signal detect windows in the centre of screen a very short time (bright flashing one time), this is inverter board damaged or worn lamps, thay all need repair or replace
hope give you some idea. please take a rating let me know how much helped you thanks!
May 20, 2009 | Dell E176FP 17" LCD Monitor
Powers up, shows test menu then black screen
This sounds like a video problem with the COMPUTER.....try the monitor on another computer. Usually, if you can see the monitor test pattern the monitor is ok.
Mar 15, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell monitor
Monitor Help CH000315, Black borders on side of screen. CH000316, Dead or black pixels. CH000403, Macintosh and/or PC monitor compatibility.
Black borders on side of screen. Additional information about what causes black borders on computer displays.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Samsung SyncMaster 205BW LCD Monitor Logo
166 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
