I am trying to find a INV15-4A8, P/N 3BS0038011, LCD Inverter for Sharp 15” TFT LQ150X1DG51. The one in my monitor is toast and I can't seem to find another like it.
-   Iam trying to find a INV15-4A8, P/N 3BS0038011, LCD Inverter for 15” TFT LQ150X1DG51. The one in my monitor is toast also and I can't seem to find another like it. seen a recommendation for http://www.chsinteractive.co.uk/ but cant seem to find one reasonably priced -   simonbrown51
I?m using a Philips 104E 14? monitor. When I use it, it goes off suddenly (no even standby LED) and...
(More)
I?m using a Philips 104E 14? monitor. When I use it, it goes off suddenly (no even standby LED) and then it couldn?t be turn on. When it?s working I can?t control the horizontal width even with the control battens. I did following troubleshooting steps : 1. All dry-joints were soldered. 2.horizontal transistor TIP122 and H-Out transistor were replaced with new ones but problem still remain same. 3 .then in order to check the voltage at H-out transistor, 230V bulb was connected to the points where E and C of the H-out transistor were connected. (and H-out was removed from the board )When I turn on the monitor I found the bulb is blinking (this is abnormal and fixed voltage should come to the h-out Tr, I think.) ******After removing the H-out transistor amber color LED came up. Can this be a Fly-back issue? Please guide how to troubleshoot this Kushan
The "Main Menu" screen keeps popping up in the middle of the monitor. Will not stay off...
(More)
The "Main Menu" screen keeps popping up in the middle of the monitor. Will not stay off when "exit" is pushed.
