When I put in my disc a sign pops up and says this disc is unreadable and unrecognized ans that we need to restart the console . . . I did and didn't work can you help me???
This is wht i do some ttymes i spray a little polish onto my disk like mr sheen or pledge and rub it with a cloth this canfill i n the sctratches and make it work better
My son's came with the same problem. I opened the casing and then the dvd drive (you tube videos did help) to realized that the dvd was not spinning. i used a connton swab and deposited a little rubbing alcool onto the center of the spinning hub waited a bit and then did the same thing with a bit of silicon lubrican. (something that will not dry up sticking. jig-a-loo worked for me) powered the unit with a blank dvd to ensure that any liquid would not damage my disk. the disk started spinning after a few try. Put back my original and boxed it... et wala
Buj
Mine was doing the same thing, I got the same message when it was standing up. As soon as i put it down flat it worked. Or if that doesn't work get a laser cleaner, the laser might be dirty if its an old system.
Cheers,
Can anyone help me? Mine only sometimes doesnt read it. And I got black ops cleaned because it had the perfect circle. Can anyone help?
Microsoft Xbox have some common problem like red lights, E74 and Disc
Read Error. Microsoft is providing extended warranty for red lights
problem, Means you will have to spend some money in order to get this
problem repaired from Microsoft also you will have to wait for 3-4
weeks to get your Xbox back. There are many reasons disc read error can
occur in your Xbox like your disc might not be clean, laser might also
be dirty and many more common problem. I would suggest you to first
clean out the disc, you are using. If that don't solve the problem you
can also take the help of DIY guide available at Internet. I think you have got good no. of options to get your Xbox repaired, Choice is yours.
Mine is did the same thing, its a problem with the disc drive and needs to either be replaced or get a new console. It is a common problem.
Same issue, says disc unrecognizable disc any help appreciated.
when i put in a 360 game it says please putin a xbox 360 game
My xbox plays dvds and only the ones it seems to like. it refuses to read most of my games, oblivion being one of them. it sucks i kinda wish i could trade it in for a ps3. Thanks microsoft, you stupid pricks. American enginering at its best. f*ck you guys
call of duty 4....... says unrecognized disk please clean with soft cloth amd restart console dosent work can anyone help,btw all of my other games work except cod 4!!!1 ANNOYING
I've got this same unplayable disc problem and the disk isn't spinning, howver i'm only 15 and don't have the mechanical expertise to dissassemble the drive and try to fix it manually.
Unrecognizable Disc error on Call of Duty 4 for Xbox 360... what do I do?
mine does the same i will get somepaste an wipe
i just bought nba live 09 put it in and was fine looked at rosters and traded ai to pistons bc the update didnt do then startd playing pure online 4 a hour now nba live 09 wont make it to the title screen without poping up unreadable disk plz clean with soft cloth and restart console
my xbox 360 isnt reading the games
my xbox doesnt play perfectly fine games sometimes, it says disc read error when the disc is brand new.
its says... reading after that it says open tray i dont know what to do its probalby laser
My XBOx
My xbox 360 is saying disc is unreadable also. Any suggestions?
my xbox plays my old dirty madden 08 and call of duty 2 but any other game it says open tray or disc read error
my xbox 360 wont read the discs it just says open tray
my games are fine but my xbox wont read them
i keep putting my fifa 09 disc in and it comes up to the area where you have to click start and it suddenly says unrecogniseable disc and every time i try it does this and its quite new and not scratched
hello, i would like to ask you why on my xbox 360 i try to play on call of duty 4 but when i get to click on multiplayer it says disc unreadable.
my disc has a few scrathes on it so this might be the case.
thanks.
it will not read my disk and says that it is unreadiable
it has a scratch all the way across the cd what should i do
when i click on multiplayer for call of duty 4
the disk says that it is unreadable
i can also play single player but when i click on multiplayer, the disk quits
the disk has little scratches but none that would mess it up this bad
Find my answer in this thread to solve this problem very easy...all the best.. :)
Solution Link . . . www.MicrosoftXbox360Console.com'
