Question about Samsung CLP 300 Laser Printer
Samsung print erro
I have a new printer..successfully installed on mac.It printed a clear test page. But now Only prints a SPL-C error - uw_color <5 and then four other short entries. Help?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 65 Answers
Check the USB printer cable.
Posted on Mar 14, 2008
SAMSUNG CLX-3185FW SPL-C ERROR - INCOMPLETE SESSION BY TIME OUT
try printing with the right driver and make sure if ur computer is 32 bit or 64 bit...
Mar 30, 2013 | SAMSUNG CLX-3185FW COL LASER MFC Projector...
Spl-c error insufficient memory
Insufficient memory seems to be caused by printing large, complex images. Printing slightly smaller will often fix the problem.
Mar 05, 2013 | Samsung CLP365W Color Laser Printer
My printer is plugged in, all of the software is installed, there is both color and black ink, the power is on and the test pages printed no problem, but it wont print anything else. it has a que set up...
It could be a print spooler problem. You have to clear the print queue first before sending out a new print job and make sure the print spooler service is running. Follow these steps on how to clear the print jobs stuck in the print queue:
1. Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder
3. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
4. Browse to Start -> Run... and type in "NET START SPOOLER" (this will restart the print spooler service)
5. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Apr 28, 2011 | Lexmark Z2300 InkJet Printer
Printer stops printing after first page and show the following on the second page: INTERNAL ERROR - Including Corrupted Data POSITION : ox23759 (145241) SYSTEM : h6fw/x1_image VERSION : SPL 5024...
Try disconnecting your printer from your pc and then uninstalling the drivers for it in your control panel. Go to the manufacturers website (Samsung) and click on the drivers and sofware area to download a new copy of the files necessary to run it.
After installing, reconnect your printer to your pc and try printing a test page to see if this has corrected the error.
Jan 16, 2011 | Samsung ML-2570 Laser Printer
I installed a new color cartridge in my printer but it comes up with cartridge missing and i can't get to print in color
Power off the All-In-One and remove the power adapter (brick) from the back of the unit. Wait 20 seconds, reinsert the adapter, and power the unit on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved. 2
Reset the All-In-One's factory defaults (click here for instructions).
Yes: Continue to Checking the Cartridges.
Open the top cover of the All-In-One. Remove both cartridges. Close the top cover. 2 Power off the All-In-One and remove the power supply brick from the back of the unit. 3
Reinsert the power supply brick into the back of the All-In-One and power the unit back on.
Does the error message reappear?
Yes: Skip to Contacting Lexmark below. There is a hardware issue with your printer and you need to contact our technical support center.
No: Continue to step 4. 4
Clean the cartridge contacts (click here for instructions) and the AIO carrier contacts
(click here for instructions). Continue to step 5. 5
Power the AIO on, reinsert the black/photo cartridge, and close the top cover. Power the All-In-One off and then on again.
Yes: Power the unit off and try step 5 with another black/photo cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark.
No: Continue to step 6. 6
Power the AIO on, reinsert the color cartridge, and close the top cover. Power the All-In-One off and then on again.
Yes: Power the unit off and try step 6 with another color cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark.
No: Try printing a test page. If the test page prints, the error is resolved
Oct 28, 2010 | Lexmark X7170 All-In-One InkJet Printer
Samsung CLP-315
try to do this set of instruction & solution:
  1. Go to Start | Control Panel | Printers And Other Hardware | Printers And Faxes. Double-click the icon for your printer to open the Documents window and clear any pending print jobs by selecting Cancel All Documents from the Printer drop-down menu
  2. Try printing a test page from the printer, not from Windows XP. Most printers have a built-in test function that's activated by holding down one or more buttons while the printer is starting up. Check your printer's user manual for instructions. If this page prints successfully, you know the problem is either with your connection or with the software in your computer.
  3. Check your printer's USB or parallel connection.
  4. Try printing something simple from Windows' Notepad. To open Notepad, go to Start | All Programs | Accessories | Notepad, type a few lines of text in a document, and try printing it. If it successfully prints, the problem is with the software program you originally tried to print from.
  5. Try printing using Windows XP's generic printer driver. Open and run the Add Printer Wizard. When you get to the Install Printer Software screen, select Generic under Manufacturer and Generic/Text Only under Printers (see Figure 2).
  6. Select No for Do You Want To Use This Printer As The Default Printer? (see Figure 3). Click Next.
  7. When prompted on the next screen, tell Windows XP to print a test page. If the page successfully prints, then you probably have a problem with your installed printer driver. Either update or reinstall the driver.
Sep 16, 2008 | Samsung CLP 300 Laser Printer
SPL-C ERROR - Including Corrupted Data
its nothing the dll file has got corrupted call to the toll free no and ask for resolution....
Aug 18, 2008 | Samsung CLP 300 Laser Printer
Does not print from Mac OX 10.5 Leopard
from a mac, you need to have a post script print option installed, the system only came with pcl
http://www.websitetoolbox.com/mb/copierquestions
Apr 04, 2008 | Ricoh Aficio 3025 All-In-One Laser Printer
CLP-510 SPL-C Error message
SPL stands for "Samsung Printer Language". You are using an USB cable that is either too long (above 6 ft.) or too thin (cheap cables).
The reason why the test page prints is because it is a very simple and small page (thinking on kbyte terms). But larger streams of data do not arrive correctly due to attenuation and the error page prints instead.
If it is absolutely necessary to connect beyong 6 ft, you need either a good quality USB cable (try the Belkin brand found at OfficeMax), or connect using a parallel cable.
Nov 01, 2007 | Samsung CLP-510 Laser Printer
Samsung CLP 300 Laser Printer Logo
288 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
