The E13 error indicates that the machine has taken too long to drain the water. Do the following.
Switch off the machine and disconnect the mains power.
Remove the access panel on the lower right front of the machine.
Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required.
4.Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked. 5.Also check that the main waste drain pipe, if you use one, is not blocked and clean if required. 6.Reconnect the power and switch the machine on. If the problem persists then do the following. 7.Switch off the machine and disconnect the mains power. 8.Check the electrical connections at the pump and make sure it is operational. 9.Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage. 10.Makes sure the pump appears clear and that the impeller looks in good condition. 11.Reconnect the hoses and then reconnect power and switch the machine on. 12.If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Machine is level but viberates on spind cycle, Have to hold machine down. one month old, used one...
(More)
Machine is level but viberates on spind cycle, Have to hold machine down. one month old, used one time.
We have a two year old Bosch 300 Nexxt washer. It has started working intermittently. It might...
(More)
We have a two year old Bosch 300 Nexxt washer. It has started working intermittently. It might finish one of every four loads. The rest of the time it just stops and sits there with no error code but the time remaining. The amount of time remaining can vary.
