Hi If it is a high pitch noise, it could be an air bubble under the steam tip. Bring the tip to the surface of the milk for a second , then down again and see if it doesn't go away. Its hard to diagnose noises on the internet.
I have a Gaggia Classic coffee machine which I haven't used for some time. I filled the resevoir...
(More)
I have a Gaggia Classic coffee machine which I haven't used for some time. I filled the resevoir with water turned the machine on and primed it, but hardley any water flows through...any suggestions?
HI. my problem stems from not enough water coming through the brewing head. there is a small amount...
(More)
HI. my problem stems from not enough water coming through the brewing head. there is a small amount of water which drips trough, but not much. It helps sometimes if I follow the process to get rid of an air-lock, but doesn't help much.
started up gaggia classic for the 1st time today. followed the instructions in the manual but when...
(More)
started up gaggia classic for the 1st time today. followed the instructions in the manual but when switching on the pump, it made ery loud noise and no hot water or steam apeared through the nozzle or filter head. Is it broken? Thank you
I need to purchase a new Turbo-Frother for my Gaggia Classic coffee machine but don't know where to...
(More)
I need to purchase a new Turbo-Frother for my Gaggia Classic coffee machine but don't know where to get one.
Its brew very slow even without coffee, i clean it everything whats next? I think the pressure its...
(More)
Its brew very slow even without coffee, i clean it everything whats next? I think the pressure its okary because the frother works perfectly. do you think i should declcified. & whats the best product THANKS
