Question about Casio EXILIM Card EX-S770 Digital Camera
Won't turn on
I too have the same problem, The camera isn't charging. just took the original one back to argos that I had for Christmas and exchanged it today for an identical model, that had the same problem too, Seems to be a commom fault.
Would be nice to find the reason.
  • kangarocks Jan 16, 2008
    Me too it has also just been flashing red so i also took it back to argos where i bought it from, they gave me a new one which is doing the exact same thing!
Hi there I have the same problem. I rang Casio Customer Service today on 020 8452 7253 Mon-Fri 08:00-18:00 & Sat 08:00 - 16:00. They were very helpful. There is a known fault with a particular batch of batteries and they are sending me out a new one. Should be with me within 3-4 days & they are confident it will solve the problem. This is my second Casio I have had too!
Posted on Jan 16, 2008
Won't turn on
Your computer isn't recognizing the camera and you may need to install some software in order for it to do so.
Another thing? Are you trying to charge it? In my experience, Jazz cameras will only charge with an adapter that is usually included with the camera. Hope this helps.
Jan 19, 2012 | Jazz DV-179 Digital Camera
My olympus vg-130 won't turn on or charge
Try this, it worked for me:-
Obtain a desktop style charger for the LI 70B battery and charge it separately from the camera. I got a charger at very low cost on eBay. I THINK that the original camera plus original charger won't cope with deeply discharged batteries. I also suggest making sure that the Auto-Power-Down is also switched ON in future. Good Luck.
Oct 21, 2011 | Cameras
Camera was low on battery. Took a couple of pictures with no problem then got it home to charge the battery and the camera is dead. Won't turn on or charge. Tried plugging it in directly with the...
1. Check if the battery is positioned and seated well in the camera.
2. If OK, and problems persists, exchange the battery and recheck.
3. If that does not help, your camera needs probably to be repaired.
Aug 05, 2011 | Olympus SP800UZ Digital Camera
Hello. My 1997 Chevy Tahoe refuses to start. The problems began with a bad fuel pump. I changed. It worked. The fuel pump died again. I changed it again and it has been working. I parked it for two weeks....
Now you have a good battery & a starter that turns over the motor
Have you cycled the key on & off with a fuel pressure gauge on the
fuel rail?
Do you have a fuel filter that isn't over 3 or 4 years old?
Have you checked for spark while cranking ? Use an old plug on the wires,
if you have ignition wires,don't ground the wire without resistance
If you removed the ducting & MAF Sensor it won't start
Tell us what you checked & exactly how that was done.
Jun 09, 2011 | 1997 Chevrolet Tahoe
When I turn the camera on , it says "lens error"
If brand new, take it back immediately to the store for exchange. It's defective.
Dec 30, 2010 | Nikon S8100 Digital Camera
My s107 bottom blades wont rotate top ones fine
There are two versions of the Syma S107. The original and BEST version is the one that has the rectangle slot on the throttle, with a ball on the right joystick. The 'cheaply made for Christmas 2010' models have an inferior build quality. Most of them have wobble problems, mainly caused by an off-centre flybar.
If you have a transmitter with a ball on the left AND the right of the joystick bases, then you have a cheap and nasty model. Also, the cheap 'CMFC2010' model has a round charging socket instead of the correct Syma square. The plug on the cheap one is also a round coaxial plug/socket affair.
I have had (and returned) four of the later Christmas models now as they all had different faults. However, I exchanged one for a 'real McCoy original' Syma and after four charges, it took off on its own (no signal from transmitter as it wasn't on) and went berserk. Then it just lost all motor functions, like a drunk student.
It goes back to ModelZone tomorrow for a refund as I still have the S031. My next little heli will be a Blade MSR.
Dec 28, 2010 | SYMA Toys industrial New Syma S107 Radio...
S800 powers on and goes off, lens stuck zoomed out.
i had the same problem with my samsung s800 camera (from new!!!) draining batteries quickly and then being left with the lense out, i took the camera back to where i got it from (argos) and after being asked if i was sure i was putting charged batteries in they sent it away for repair and it turned out that the lense mechanism was broken, i think they charged me £10 to get it fixed but i have had no problems since then.
Dec 10, 2008 | Samsung Digimax S800 Digital Camera
We have a new Samsung 10 megp. camera.
we are going back to the Argos Store where we bought the camera to see if they will exchange it for another one as we have the receipt when we bought it two months ago.
Oct 02, 2008 | Cameras
My camera will not work
try to put regular batteries in it to reset it and if it turn on shut it off and take out your SD card turn it back on and go to the menu screen and format it and then reset it, it should work after that if not all i can say to do is to send it in to sansung and have them fix it.
Jan 26, 2008 | Samsung Digimax D53 Digital Camera
Casio EXILIM  Card EX-S770 Digital Camera Logo
70 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
