Had this problem with my PC in the past. resetting it seems to fix it. how do you reset Acer Aspire T180-GB7Z PC thanks How do you use the acer restore disks. Tried placing in drive with no effect, do you have to reformat the c: drive then place in drive?.
Perform a system recovery:
Does not come with recovery cd's - there is a program that allows you to burn the disks or
recover.
3 ways:
1. If in Windows - Start - Programs - Acer empowering technology - Acer E-recovery management -
click on Restore at bottom then "Restore to factory default settings"
2. Or click on Burn disks instead of restore
3. if unable to ge into Windows then Alt/F10 during boot right after Acer splash screen on startup
End User Technical Support and Service (USA only)
For end user technical support, spare parts and service: 1.800.816.2237
Your pc must be set to start from cd go into the bios under boot from cd then your pc will start from cd and be able to start the restore
what do you mean this has no baring on what you asked this is the correct way to reset you pc ask any tech. you don't have to format the drive cause the cd will do it all for you wipe primary partition and reinstall windows if you have any questions ask don't just give us techs bad ratings we are here to help.
