Question about ViewSonic VX910 19" LCD Monitor
LCD monitor problems.
I have two Viewsonic LCD's: models VE700 and VX910. The VE700, turns on, shows a gray screen for 3 seconds then black screen, the power stays on. The VX910, turns on, I see all the bootup process, when it gets to windows shows the desktop for 2 seconds then black screen, power stays on.
I have tried them both on 4 different computers, same problem. I have tried other monitors on the same computers, all work, so I know it's not a computer problem.
What can be wrong with the LCD's ? Inverter ? Backlight ?
Much appreciated. Thank you, Ed.
MY LCD SCREEN COMES ON AND SAYS OFF MODE IN 5SECS AND CUTS OFF EACH TIME I TURNS IT ON
Posted on Apr 02, 2008
  • 372 Answers
Hi.
If the monitors use seperate plug in power supply EG 12 to 24volts it could be that at fault.
Or it could be the invertor at fault.
I have had some success repairing invertors if you can use A meter remove invertor Panels & check accross the coils with meter set to ohms all the coils should read identical chances are you will find one set of windings either dead short or open circuit. This will be the faulty coil hopefully as your monitors are all the same make the coils will be the same.
Carefully desolder faulty coil & fit one that reads good from a doner board.
Look for any SMD type fuses & check or replace them & thats it I have done quite a few now using this method.
Give it a go.
http://dysonmanuals.llc.nu/
Chris..
Posted on Dec 30, 2007
I have a ViewSonic VX910 LCD monitor. I turn it on and it comes on for a second then goes black. I did replaced all five capacitors in the power supply board, but it didn't help, still the same problem....
AllI can think of is that a tripler or inverter could be breaking down, causing the unit to go into auto
shutdown mode. Some devise is breaking down, and causing the unit to shut down.
Not an easy problem to troubleshoot unless you've got a schematic and tech skills.
Hope this helps
Mar 26, 2011 | ViewSonic VX910 19" LCD Monitor
I turn it on and it comes on for a second then the goes black
You need to open it up and inspect the capacitors (look for bulging top/seal), burnt inverter transformers, resistors, etc. in the power supply/Inverter board first, post back what you find so we can guide you further. See example of failed Viewsonic monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 16, 2010 | ViewSonic VX910 19" LCD Monitor
Monitor turns black after 2 seconds, Viewsonic VX910
Check the power supply first for bad caps, then check to see if you do have 12vdc feeding the the inverter circuits, worst case will be the lamps, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 21, 2010 | ViewSonic VX910 19" LCD Monitor
Where can I get a power cord for the ViewSonic VE700 LCD Monitor
Hello there:
Most of the computer stores or a electronics store like office depot or radio shack or walmart or k-mart ect ect ....will have these cords
Furthermore if you have a second hand store in your area they might have them there too
Hope this is very helpful for you>
Best regards Michael
Jan 05, 2010 | ViewSonic VE700 17" LCD Monitor
My screen turned black and began flashing.
Kim, The LCD display requires WHITE light so you can see all the colors on the screen. Most BLACK screen problems will be a power supply problem internal to the monitor. I monitor is still under warranty, have Viewsonic repair it. Here are a few more options that could be available if unit is out of warranty. 1. Trade in for new widescreen display. Please note that the electronics technician at the store will evaluate your monitor and try to repair it for less than $10 in parts! He or she will keep it as a spare unit or sell your monitor for $40 - $60 to a buddy that needs a spare or second monitor. 2. Check to see if Viewsonic has a CASH+old unit swap-out program. They ship you a REFURBISHED same model unit w/ 30day warranty. Yes! They will REFURBISH your old monitor and ship it to another customer. But that's only if a swap program is in effect! 3. Check with a local TV/LCD monitor repair shop, to see if they refurbish LCD monitors with new or rebuilt "switch-mode-power-supply" / "inverter supply" / "cold-cathode-fluoiescent-lamps" . 4. Most costly option. Buy new display AND have your VX910 repaired and kept as spare unit! Before you do any of the above mentioned options visit (FYI) YOUTUBE and search for and view the longer (8-12 minute) video clips of "LCD monitor repair" and "LCD monitor disassembly" to learn what the most common causes of LCD BLACK SCREEN failure are and what parts are used to fix them. Also visit www.ccl-la.com/badcaps.htm and www.lcdparts.com , www.badcaps.net for more information. If your VX910 falls into the FAILED CCFL backlight catagory get back here to fixya and let us know what option you will persue. If this was helpful to you or someone else, rate this response on fixya. 12fixlouie by for now.
Nov 04, 2009 | ViewSonic VX910 19" LCD Monitor
Iimj9 sonic tft - lcd monitor goes out after 3 seconds
You should remove power for a few min then hook up and try again.electronics sometimes need to be reset after any fluctuation in power. Good Luck
Jan 26, 2009 | ViewSonic VX910 19" LCD Monitor
The problems is my monitor (VeiwSonic VX910) is blinking evey few seconds from destktop screen to black screen. help!!!
PSU- Board, Rev.C
Item: B-PS-0204-0076
Compatible with: VX710 VX910 VX912 VX924
BER-2 Number: D9 SCRAP NOT AUTHORIZED
(This item has been discontinued and not available to order.)
Please order B-00002481 instead. Your Price: US$45.00 Each
Jan 08, 2008 | ViewSonic VX910 19" LCD Monitor
Viewsonic vx 910
it is power problem pls show it service personnel
Sep 21, 2007 | ViewSonic VX910 19" LCD Monitor
ViewSonic VX910 19" LCD Monitor Logo
246 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
