Question about HP Photosmart 2710 All-In-One InkJet Printer
Glass dirty on bottom side
How do I remove the glass to clean the underside.
  • rowdy_aussie Apr 09, 2008
    How do I clean the glass on a HP Photosmart 2710 all-in-one?
    New Friend:
Question is how to clean bottom of scanner glass. The HP link is not helpful, as HP only provides info for cleaning top of glass, and states that info for cleaning bottom of all-in-one scanner glass is "not available for any product". Cleaning underside requires HP service!
Posted on May 10, 2016
How to clean the underside of the glass in a HP scanjet 2400
Hi ,
You probably already found this :
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/performMaintDisplay/?sp4ts.oid=297429&spf_p.tpst=psiContentDisplay&spf_p.prp_psiContentDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c01275864-2%257CdocLocale%253Den_US&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
According to it , you should normaly contact a HP technician to have the job done . Nevertheless , I succeeded to clean the underside of the glass inside a HP Scanjet 5470C wich seems similar to your model 2400 . If you take of the lid of the unit , you should find two screws in the opening of the hinges . Unscrew them and lift up the the whole top of the unit . You might encounter somme kind of resistance during the operation but I finally succeeded to get the it free that way .
Best regards .
Sep 04, 2014 | HP ScanJet 2400 Flatbed Scanner
How do you clean the underside of hp5590 glass?
Detach the ADF assembly. Remove the 4 case screws from the scanner bottom. The case has a notch at the back that has to be unclipped to separate the top and bottom. Clean the glass underside repeatedly, I use methylated spirits on soft toilet roll. Check in the glare of the scanner light, and reassemble.
May 19, 2011 | HP Scanjet 5590 Flatbed Scanner
I want to clean the underside scanning glass of the HP C4180 scanner/printer because when I scann, the top is clean, but the scaned pictures look like they have little specks of dust all over the scanned...
It takes several steps to remove the glass carrier for cleaning, but it's not really difficult. You'll need a T10 Torx screwdriver, eyeglasses cleaner or similar, and a lint-free microfiber cloth.
1) Remove usb and power cables. Flip the front covers open (revealing the cartridge-insertion area). Remove 2 screws from the right-side panel, and remove that panel.
2) Open the photo-paper holder on the left side, depress plastic tabs on its top and bottom so it can swing out 90 degrees, and remove it.
3) Remove 2 screws from the left-side panel, and remove the panel. This exposes the gears of the paper-handling mechanism; take care not to move the gears. Disconnect the three ribbon cables connected the bottom circuit board.
4) Flip up the LCD, exposing a screw. (Note that this one is shorter than all of the others.) Remove the screw. Lift the scanner lid and remove two screws just behind the rear of the glass. Close the cover. Lift the rear of the glass carrier, then slide it back slightly to remove it. Take care not to move the scanner bar that remains in the main body of the machine.
5) Keeping the lid shut, flip the glass carrier over over. Spray cleaner on the glass and wipe; repeat as needed. I use a bright light at a low angle to check for particles on the glass.
To reassemble, just reverse the steps. Finish by cleaning the top of the glass.
Paul Hays
Sep 19, 2010 | HP Photosmart C4180 All-In-One InkJet...
I have a ricoh 2232c. Do you know how I can clean
In order to clean the optics, you have to remove the two optic covers (one over the **** glass on the left and one on the rear side of the main platen glass). Each cover should have 2 or 3 screws.
Clean the **** glass and platen glass with alcohol and a lint-free rag (both sides) and blow compressed air onto the mirrors, lamp, and reflector. It's a good idea to turn off the copier before doing this.
When reassembling, clean the white strip on the underside of the **** glass cover as well.
May 08, 2010 | Ricoh Aficio 2232C Color Copier
Platen glass dirty clean platen glass
user mode
common settings
additional functions
13. adf dirty error
display(default) / do not display
Sep 18, 2009 | Canon imageRUNNER 1023iF Black and White...
Cleaning the Glass
OPEN THE SCANNER UNITE SIDE AND CLEAN OFF ALL DIRTS ON THE OTHER SIDE OF THE GLASS,COVER IT BACK AND HERE YOU GO...THE PRINTER SCANSS CLEAN AND CLEAR
Feb 05, 2009 | HP PSC 750 All-In-One InkJet Printer
HP 6110 scanner glass is cloudy
Here is how, but it seems a lot of work.
- Remove all the torx-screws
- Remove the little glass on the left side
- Remove the Control Panel Cover (lifted it a little with a screwdriver and released two latches)
- Remove the Control Panel itself (another two latches&move to the left)
- The whole top of the 6110 is attached to the bottom with 4 latches. I remove that, turn it around and clean the glass.
Note: The cables between 6110-bottom and control panel/feeding unit are long enough to set those things aside.
Dec 06, 2008 | HP OfficeJet 6110 All-In-One InkJet...
How to clean underside of platen?
The underside of the scanner glass can only be reached by a a canon service tech. The compartment is supposed to be sealed and dust-free, so if it has gotten dirty, you should send the unit back to Canon for servicing.
Feb 07, 2008 | Canon imageCLASS D320 All-In-One Laser...
HP photosmart 2710 dirty glass
hi,
no way.... u cannot clean the underside of the glass... u can clean the glass using a lint free cloth....
thanks and regards
agnel
Dec 30, 2007 | HP Photosmart 2710 All-In-One InkJet...
How do I access the underside of the Flatbed scanner to clean it?
remove the lid by lifting up. There are two philips head screws exposed. Remove screws and lift top of scanner off. Pay particular attention to thumb wheel position when lifting. Go to computer repair center and buy double sided tape. replace tape and reverse process
Nov 08, 2007 | Umax Astra 1200S Flatbed Scanner
HP Photosmart 2710 All-In-One InkJet Printer Logo
255 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
