Question about MSI K8MM-ILSR Motherboard
Want bootup says checksum bad
This is a Gateway 614GE desktop , MSI Motherboard K8MM-ILSR socket 754 AMD-Athlon 64 3400+, it worked fine for about 2 years up till about a year ago, then one day I had it on working on some data when all at once the screen went gray and started flashing garbage real fast, I turned it off waited a few minutes, turned it back on, same thing. I have done every thing I can think of including, reformatting the hard drive, reloading windows XP, inserting a new cmos battery, etc,etc, it boots-up if you play with it long enough then it goes to messing up again, HELP
When I turn it on it gets to the energy compliant screen that list all of the drives, so on & so forth, then down at the bottom theres a message that reads:
CMOS/GPNV checksum bad, what does this mean?
Then it says:
F1 to Run Setup
F2 to Load Default Values and Continue
When I press F2 it goes to MS's logo screen and just sets there.
If I press F1 it goes to reload data from so and so date.
Like I say it will finaly come up but not for long.
Is there any tests I can run?
Do I need a new Motherboard or a new CPU or both, and if so is there another or better board I can use in this machine, I would rather have Intel.
I bought another computer right after the Gateway went down, I think its still a good machine, I think it was heat that got it, no fault of the machines.
Thanks in advance for any help you can give
  • bigmon Jan 06, 2008
    Thanks Demolitio,
    Is there a motherboard I could replace this (MSI Motherboard K8MM-ILSR socket 754 AMD-Athlon 64 3400+) with? It seems this board is hard to find.
  • 108 Answers
Usually, the message you are seeing is displayed when your CMOS loses power abnormally. Even when your computer is turned off, there should always be a low-level charge from the battery, keeping track of your PC's clock, and storing information about your BIOS settings.
If the CMOS battery is dying, it will produce a weaker charge, or continuously start and stop providing power, which will trigger that message. as a result, you are losing all your BIOS settings that you are configuring each and every time, and getting that message when it happens.
It's odd that you would be getting that message when you replaced the battery, but I'd try replacing it with another one just to be sure. If it doesn't fix the problem, the motherboard may need to be replaced. In this case, the problem could lie with wireing between the casing and the chip, or even be in the chip on the circuit board itself.
You could also try flashing the motherboard, but only use that as a last resort- you could finish toasting it. Also, I can't guarantee it would fix it in the future, as all you're doing is adressing the symptoms, and forgetting about the cause.
Posted on Dec 30, 2007
  • Vernon Simkins Jan 06, 2008
    Hi Bigmon,
    To answer your second question, If the motherboard is still under warranty, you might want to check with MSI to see if you can get a replacement,
    Anyways, there seems to be quite a few ebay
    auctions for your motherboard, if you don't mind used equipment, or
    dealing with other bidders.
    however, if you want brand new, you could try going with a different
    socket 754 motherboard. all you would have to do is double-check the specs, to make sure that the motherboard you buy has the same
    features, and hardware support as the one your replacing it with, so
    you don't lose anything you may normally use.
    here are a couple listings for your motherboard type in online stores I came across that may help: (american site. replace .com with .ca, if you're Canadian)
    Oh, and one more thing... when you go to replace the motherboard, make sure you back up anything important on your system first. Certain versions of windows have a tendency to scream at you when a new system board is added (the system might crash repeatedly at startup, or cause frequent errors), so you might end up having to reformat.
    also, if you do end up reformatting- make sure you are re-installing a retail/full version copy of Windows. if your PC came with "restore CDs", they might not work- some of them look for specific hardware on your system, and will refuse it if they don't like what they see.
    hope this helps!
I am using ASUS K8VMX motherboard with AMD Athlon 64 2800+ motherboard. Now my motherboard has gone bad. I want to change it. Suggest which motherboard should i use (754 socket)
Whatever board that is in a microATX format and has a 754 socket will do - they all had the same general hardware characteristics and requirements - so get the cheapest you can find.
Apr 17, 2011 | AMD Athlon-64 2800 CPU and Mother Board...
Video driver for windows xp msi-k8mm-v-7142
You can download the drivers from MSI WEB support site,select your model motherboard to download :-
Jan 31, 2011 | MSI K8MM-V (MS7142-010) Socket 754 Micro...
I am using amd sempron LE-1100 i want to upgrade to a gaming pc so that i can play the sims3. so if i like to upgrade to amd athlon x2 how to know my socket type. please help
Your socket is AM2. You can put any AMD processor that has AM2. If the processor is AM3 just upgrade the bios of your motherboard and it should work. If you need further assistance, just leave a comment. Cheers
May 24, 2010 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Installed new processor and computer doesnt turn on just flashes green steadily?
CPU • Supports 64-bit AMD® Athlon™ 64 processor (Socket 754) • Supports 2800+, 3000+, 3200+, 3400+, 3700+ • Supports Sempron 2600+, 2800+, 3000+, 3100+, 3300+ Chipset • VIA® K8M800-CE Chipset - HyperTransport connection to AMD Next Generation of CPU - 8 or 16 bit control/ address. data transfer both directions - 800/600/400/200MHz "Double Data Rate" operation both direction - AGP v3.0 compliant with 8X transfer mode - On-board Graphic shared up to 64MB • VIA® VT8237R Chipset - Ultra DMA 66/100/133 master mode EIDE controller - Integrated dual channel native Serial ATA/RAID controller that will supply 150MB/s and support RAID 0, RAID 1 - ACPI & PC2001 compliant enhanced power management - Supports 8 USB2.0 ports. (Rear x4/ Front x4) Main Memory • Supports two 184-pin DDR SDRAMs up to 2GB memory size • Supports DDR400*/DDR333/DDR266 DDR SDRAM (*Refer to MSI recommended modules) • Note: PC3200 (DDR400) maximum 4 banks (2 double-sided) only
I can't seem to find any usefull information as to why there may be a LED flashing on the motherboard. Re-check the memory speed, and configuration, as well as the CPU that it is supported. This seems to be a fairly new motherboard, it may still be under warranty, contact MSI and request an RMA if you feel the motherboard is faulty.
May 31, 2009 | MSI K8MM-V Motherboard
Program says it cannot find any previous programs and change to win 98 then it says to put win xp back in cd then back and forth confused!!
my MSI MOTHER BOARD model no. is K8MM-ILSR(601-6741-030)
MY PROBLEMis that ......... VIA SATA RAID Driver is not working. Without this ican't install OS in my system. this driver in floppy thats why floppyis corrupt. on my floppy writen like that ......... G72-VASA040 VIASATA RAID Driver For VT6420/8237. I Want this software. my mail id
i have msi mother board,amd athlon 64 bit processor,sata hdd 120GB,
May 04, 2009 | AOpen Computers & Internet
Try to install 2gb ddr memory on MS-6741 motherboard
pls check you motherboard manual if it accept that kind of memory because some board cannot accept.
Jan 08, 2009 | MSI K8MM-ILSR Motherboard
Cpu upgrade
According to the spec sheet on the MSI website, this motherboard will take up to a 3700+ Athlon. Check out the link:)
Further testing is being done on this board, but here is the UPDATED CPU compatibility chart:)
Dec 30, 2008 | MSI K8MM-ILSR (MS6741030) Motherboard
Biostar offers NF61S MICRO 754 Motherboard + AMD Mobile Athlon 3200+ (COMBO56), NF61S MICRO 754 Motherboard + AMD Mobile Sempron 3300+ (COMBO56A),NF61S MICRO
Motherboard Processor:
Socket 754
Supports AMD Athlon 64/Sempron Processor
Support AMD HyperTransport up to 1.6G
Supports AMD Cool'nQuiet Technology
• Chipset:
NVIDIA MCP61S(GeForce 6100/nForce 405)
they are the same motherboard .hope this helps pls appreciate by rating it as fixyaa
Oct 10, 2008 | Computers & Internet
MSI K8MM-ILSR Motherboard Logo
162 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
