Question about Gigabyte 7VM400M-RZ (GA-7VM400M-RZ) Motherboard
Disabeling display drivers on motherboard
I have a gigabyte agp 8 x and I want to use a seperate graphics card, but the motherboard is not detecting it when I connect it?? any idea on how to turn the inbuilt grphics off??
    Novelist:
  • 108 Answers
If there's a configuration option for it, it would be in your BIOS. every model has a slightly different way they portray this option. some BIOSes tell you straight out, labeling it "enable/disable onboard video" option. others give you a prompt asking what you would like to ''prioritize'' for graphics. there are also specific jumper configurations you can use that would be documented in your motherboard's manual.
However, you may not find any such option there, as most boards today automatically disable onboard video when a card is installed. Make sure that the video card you are installing is snug and secure in the AGP slot, with all pins in the proper places, and with the plastic clamp locking it in place. It shouldn't feel loose, or be bent when you're positioning it.
Also, make sure that if the card needs to be plugged in to your power supply directly (there should be a white jack or two with four metal pins on one side of the card if there is), that you do so. If the card isn't getting any power, that could be why the motherboard isn't detecting it. Also, check to see if your power supply can handle the rating... some video cards require stupidly high amounts of power to run properly.
if all this doesn't help, either the video card itself or the AGP port ont he motherboard is malfunctioning. test a different video card if you have one in that system board, or take it to someone else to test on their computer. If you recently bought the card, you can have it sent in to the store you bought it from, and I'm sure that if you request it, they will test the video card themselves to see if it's defective, and give you a replacement if it is.
Posted on Dec 30, 2007
Powerup no display
Try rebooting, go into BIOS, and look for option to set graphics/display to card instead of on board or something like that. Should do the trick
Apr 10, 2014 | Gigabyte GA-8IRX Motherboard
I have a Gigabyte GA-K8VM800M Motherboard with 2gb ram. I want to disable the onboard graphics card and add another VGA card. Which card should I go for?? Will adding VGA card, show physical memory as 2gb...
Hello you can download the manual, and drivers here:
http://www.gigabyte.com/products/product-page.aspx?pid=1810#manual
You can add a graphic card 1 x AGP slot (8x/4x-AGP 3.0 compliant), supports 1.5v display card only.
And Max capacity: Up to 2GB DDR400 RAM by 2 DIMM slots.
ATI/AMD makes very good graphic cards.
Adding a graphic card on the mainboard will not slow the physical memory. It has it`s own ram.
Good luck
Jun 18, 2012 | Gigabyte GA-K8VM800M Motherboard
I want to get gigabyte 9250-1GI VGA driver
You can download the video and device drivers from Gigabyte WEBsupport site, select your model motherboard to download :- http://www.gigabyte.com/support-downloads/support-downloads.aspx
Jun 25, 2011 | Gigabyte RADEON 9250 AGP8X 128MB DVI...
Hi i have a motherboard gigabyte 7nf-rz this motherboard dont have an integrated vga so i have to use a video card, i have an nvidia 6200 agp video card conected the vieo card to it an theres no video on...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electric extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
cnetdownload.com on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need or major geeks download this graphics driver this will depend on your operating system
http://download.cnet.com/%7Bvalue=http://www.download.com/ati-catalyst-display-driver/3000-2108_4-10608736.html
This is a WHQL release from the Release 260 family of drivers. This driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, and 400-series desktop GPUs as well as ION desktop GPUs. What
Apr 19, 2011 | Gigabyte 7NF-RZ (GA-7NF-RZ) Motherboard
For
I have not been able to add any AGP card to my PC.
My PC is a cube PC so I have been trying to install a "low end" AGP video card without a separate power connector. My only really requires are DirectX 9.x support and a minimum of 128MB (and no power connector)
The card I am currently trying to install is a Gigabyte ATI Radeon 9600Pro with 256MB.
I have also tried a ATI Radeon 9550 with 256MB and a Nvidia card
I have done all of the usual things, such as disabling onboard graphics, removing old video drivers, verified latest chipset drivers are installed, I reviewed the graphic adapter and don't see any conflicts etc.
I wonder if any of the cards I am trying to install will work with my AGP slot.
The manual for this Gigabyte card states "AGP 3.0 Slot or greater is required"
Unfortunately, this requirement wasn't on the Gigabyte or NewEgg web sites or the back of the box. Only in the install manual.
My Motherboard manual states "AGP 1.5v Card is required".
I got great AGP information from www.playtool.com. I used some of the tools suggested there such as Sandra Lite and other tools to try to determine what version my AGP Slot is. These tools don't seem to clearly state what
My PC is a Small Form Factor PC with 220W Power Supply.
It has integrated Intel Extreme Graphics
gBox P4 Blue CF-986L
Motherboard is a CFI-968L with last bios released (1.04)
www.american-media.com
Pentium 4 3.06Ghz
1G RAM
80G HD
Chipset is Intel 845GE
Windows XP Home
This is a awesome PC and I really would like to extend the life of it my adding any AGP card that supports DirectX 9.x
Read more: Adding ATI Radeon 9600Pro - AGP Slot Issue? - Tech Support Forum http://www.techsupportforum.com/forums/f24/adding-ati-radeon-9600pro-agp-slot-issue-128485.html#ixzz1FKivifx5
Feb 28, 2011 | ATI RADEON 9600 Pro, (256 MB) AGP Graphic...
I want to add a grapic card to my motherboard..
you will need an AGP type graphics card for this motherboard, not a PCI-E....hope this helps
Feb 08, 2010 | Gigabyte GA-7VKMP Motherboard
Is visiontek a radeon hd 2400 pro agp 8 compatible w/ p4s800- mx?
ATI has recently written some better drivers for the 2400 Pro AGP cards,... Make sure the setting in the BIOS for the motherboard is set to the AGP or PCI for primary video. For AGP, make sure that you have the power from the power supply connected to the video card. Make sure that your motherboard does support 8X AGP video cards. If you are not sure, please check with motherboard manufacturer for compatibility.
Dec 13, 2008 | VisionTek ATI RADEON HD2400 Pro Edition...
ATI Radeon Saphire 9600Pro AGP Graphics Card
It appears that the mobo is AGP 8x, and this video card also appears to be AGP 8x - so you should be able to use it just fine.
Jan 26, 2008 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
AGP card support
Hi, Unfortunately no AGP slot nor PCI-E. The Gigabyte GA-8I845GV motherboard has only 3 Expansion Slots and all of the are PCI (33MHz & PCI 2.2 compliantt). From their website, here's an image of the motherboard http://www.giga-byte.com.tw/FileList/Image/motherboard_productimage_ga-8i845gv_big.jpg It has a built-in Intel® Extreme Graphics Engine (845GV chipset) for video with max of 128 mb shared memory. Should you wish to install an add-on 3rd party PCI video card, Inno3D FX5500 256ddr PCI slot tv-dvi are still available (at least in my location) for an equivalent of about 3.5K INR (80USD+). Hope this gives you an idea. Good luck and kind regards.
Aug 19, 2007 | Gigabyte GA-8I845GV-C (GBSA4LB)...
Gigabyte 7VM400M-RZ (GA-7VM400M-RZ) Motherboard Logo
81 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
