Long boot up time with Vista
I have a Gateway running Vista Home Premium. It has a Quad core Q6600
and 3 gigs of memory. Start up time was normal until I added my networked Xerox Phase 6360 using latest drivers and an external USB WD500 hard drive. The time from the Gateway logo to the initial startup of Vista went from a few seconds to 6-7 minutes. Vista bootup from then on is the same. I have tried disconnecting both and it does't seem to help or revert to a normal startup. What happened and is there anything I can do to fix problem. Gateway tells me the only fix is a re-install of OS. The only software I have put on machine thusfar is Microsoft Home office, Corel X3 with Vista update, and Adobe Photoshp 6.0. I would appreciate any help in fixing or trouble shooting this problem. Thanks
  • 2,427 Answers
Ok what you need to do is clean up your registry and then defrag your registry and hard drive
Download TUNEUP UTILITIES and use that, it has a trial version in case you cant afford to buy it
Posted on Dec 30, 2007
How to insert an sd card on a packard bell windows vista home premium computer
Windows logo button ('Start') > Computer > Removable devices.
DOUBLE-click on the file name to the right of - Removable devices
Regards,
joecoolvette
Mar 21, 2013 | Packard Bell Computers & Internet
Can i make a dual core run like a quad core, or add cores with out changing mother board?
You may be able to install a quad core processor on your motherboard, will need the model to check.
You can't make new cores out of nothing though.
Oct 22, 2012 | HP Compaq SR5702F PC Desktop
Computer will not boot up
Try starting in safe mode.
Jul 22, 2009 | Dell Computers & Internet
Is 1 gig of ram enough memory to support vista to run?
Hey there you want to use vista?? lol good luck. You need a min of 2 gigs ram to run vista but should ideally have 4 gigs for good operation. vista is a memory hog. You can change the configuration to use less but still need at least 2 gigs
seth
Jun 27, 2009 | HP Pavilion dv6000z Notebook
To buy pc
I would recommend a Dell Inspiron 531. They can be slightly hard to find, but they are cheap and pretty fast. Here are the specs for it:
300W LITE-ON PSU
2.2 GHz AMD Sempron LE-1250 CPU (waaaay faster than it sounds)
nVIDIA Integrated Graphics
Realtek HD Capable Integrated Sound
Dell 0RY206 Motherboard
PBDS DVD-ROM/CD-RW Drive
160 GB WD HDD
2 GB DDR2 RAM
Windows Vista Home Premium
May 18, 2009 | Acer Aspire 2100 (91.AB675.D02) PC Desktop
How much should installing I tunes on a new gateway FX model slow downloads from other links?
If the resources for the machine are a quad core processor with 6 gigs of memory and a 640 gig hard drive, then not at all. Are you running Windows Vista 64bit edition? Ive had issues with itunes running properly under this OS. Grab the latest copy from Apple's website (make sure you uninstall the old copy first, do not install the new copy on top of the old one). Check for any Windows updates and install them before installing the new itunes.
Mar 01, 2009 | Gateway FX4710-UB003A Core 2 Quad Q9300...
8400GS graphics card installed causing sound distortion
You do know you can increase your integrated video's memory in the bios. Up to 1GB. (Yes, I know you currently only have 1GB of system memory) but you can kick it up to 128Mb & Vista should still run.
Your 1GB system memory is shared with the on-board video card.
I'd like you to clean out the PCI-E slot with some cotton swabs & house hold Alcohol. (do not over soak the swabs). Clean the pny's copper contacts as well. Get a really strong flash light & look into the PCI-E slot & look for dust, dirt & check the copper connectors are not bent or twisted. Re-install the PCI-E card & set the bios back to PCI-E. Try again. Even if the system reverts to weird, install the 8400's software & driver. Re-start the system. See if the system runs normal. Also would not hurt to check for Window's updates. After all that, if system does not function normally I suspect there is something wrong with the 8400 card.
Good luck & let me know if this has helped.
Have a great day.
Mar 15, 2008 | ASUS P5VD2-MX SE Motherboard
Motherboard not work as it should work
hi some motherboard does not support vista. try to install windows Xp. if it keeps working then the problem will be the os, otherwise try to upgrade ur bios or ur supplier
Mar 15, 2008 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
Computers & Internet Logo
171 people viewed this question
Alun Cox
David Payne
David Payne
