Question about Samsung SyncMaster 720N Monitor
Power button won't turn off monitor
The button acts normal and clicks but nothing happens. Been advised to clean control panel circuit or replace the tact switch? How do I clean the control panel circuit? and what is a tact switch? Also the Adjust lock will not come off.....
even if don't touch the monitor controls the menu switches on and off as it wishes just like that
syncmaster 720N
  • bujrumaga Jan 17, 2008
    I have the same problem like Kumba. Buttons were works normally and I never had touch them often so I don't know how they can't work just like because of bad quality of buttons. In the beggining of this problem was message every 10 seconds "Monitor Adjustment" it was very anoying. Now, even if don't touch the monitor controls the menu switches on and off as it wishes just like that, but sometimes works ok.
  • ecojan Feb 21, 2008
    All the buttons seem to have a mind of their own,I can't control any of them.
I figure it out that best solution for the problem is to press and hold button Monitor adjustment with same tape or stuck it with piece of wood. Message never appear it again!
Posted on Feb 27, 2008
    Problem Solver:
  • 19 Answers
Problem is made by switches which are bad quality, you have to take your monitor to the nearest samsung service center or if you want you can change this switches by yourself. You can find them in conrad stores named phap3363 and art.nr: 700310 - 62.
Best regards
Posted on Jan 17, 2008
Why are lights flashing but machine not working?
It can be a number of things. The buttons need cleaning, a bad solder joint or broken wire, a faulty IC on the control circuit board, the circuit board with the buttons could be loose and not making correct contact, etc.
Only way to know is take it apart. You will need a good flashlight and a long straight screwdriver to get to some of the clips. It is NOT an easy task. Look for tutorials on youtube, etc.
May 06, 2014 | Keurig Elite B40 Coffee Maker
No sign of life to our 5 year old D/W except flashing "CLEAN" L.E.D.
7-1 heating circuit problem control programmed to shut down machine when no rise in water temp during heat cycle, you either have an open heating element or wire burnt a shorted thermistor or a bad control not outputing 120VAC to the heater you can reset the control by placing the machine into diagnostic hit cancel button to turn off all the lights press heated dry-normal, heated dry- normal within 6 seconds lights should come on press cancel unit should start it will run till same part of cycle reached and lock out again if it has not been removed the little black panel below the door remove should have the tech sheet in a plastic pouch which explains how to check the components mentioned earlier,
Apr 03, 2014 | Whirlpool GU2800XTV Dishwasher
Maytag epic dryer
Without seeing dryer and checking it , best guess could be main control board problem
Dec 08, 2013 | Dryers
The power will turn it on buit not off and the channel button will not turn the channel
When you turn it on, are you using the remote control or the power button on the side of the unit?
When pressing any buttons on the unit, be it the power from the channel selectors, you should hear a 'click' from the actual button on the printed circuit board inside the unit.
If you are not hearing this 'click' the plastic mounts holding the printed circuit board in place may have become dislodged from its position. You can rectify this but it will involve removing the back of the unit to access where you need to get too.
If you are hearing this 'click' and still nothing is happening, it's possible the buttons have become faulty and you may need to either replace the buttons or the entire printed circuit board that holds the buttons.
I hope this helps. Good luck.
Sep 05, 2010 | Televison & Video
Dell 1900f monitor contrast/brightness problem
CLick start/run then type in dxdiag. Go to the display tab and click test dirext3d. There should be an 3d cube that comes up and spins around. After the cube leave cancel everything else and close dxdiag, Your problem should be solved for a pretty long time. If it happens again just follow the steps again.
Jun 11, 2009 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Just won't work!!
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
I would also advise to check the door switch as well. make sure the wires are connected to the switch and it is working. replace if found to be faulty.
Check the control as well. if the control is malfunctioning as you stated, this will be the logical solution here. replace the control board.
May 29, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Cannot turn off monitor
It is problem with power settings. Start/Control Panel/Power Options -- and then pick a Power Scheme from the drop down list and make whatever modifications you want to the settings that power down your monitor
Feb 28, 2009 | Dell E196FP 19" LCD Monitor
Computer shuts down but does not turn off
Mchem, you actually have 2 separate issues going on there.
  • Open control panel > open the system control panel
  • in the system properties, click on the advanced tab
  • in the startup and recovery section, click the settings button
  • In the startup and recovery dialog box, under system failure, remove the check from the automatically restart option
  • click ok
  • click ok
  • Open control panel > open power options
  • in the power options properties, select the advanced tab,
  • in the power buttons section,
  • When I press the power button on my computer: click on the drop down menu and select the shut down option
  • click ok
Sebastien123, you only need to run the first part of this solution.
Dec 20, 2007 | EliteGroup ECS PF5 EXTREME...
Well, I noticed this after I installed win xp sp3. My monitor won't turn offwhen I click the button. I have to set my power setting to a certain timeframe then require a relogin but the monitor just won't turn off otherwise.
Oct 23, 2007 | Sharp LL173C 17" Flat Panel LCD Monitor
Power button won't turn monitor off?
ok,your monitor is in  a very simple problem.clean the control panel circuit of your monitor,or if it is not working replace the tact switch in your monitor.
Oct 18, 2007 | Sharp LL173C 17" Flat Panel LCD Monitor
Samsung SyncMaster 720N Monitor Logo
1,909 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
