GoVideo DVR4400 DVD Player/VCR Logo
Posted on Dec 30, 2007
DVD VCR Not Functioning
DVD VCR will not operate whether trying to use the manual buttons on the unit itself or the remote....locked up?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 19, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
176
Points
1helpful
Unit will play a VHS when using button manually. It doesnt matter which button is pressed on the remote, the display on the unit says 'DVD 3'
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
http://electro-medical.blogspot.com/
http://schematicscom.blogspot.com
6answers
Unlock my dvd player
try this
Power Up the unit with NO Disc in the tray.
Open the tray
Press the SETUP Button on the remote control
Navigate to the PREFERENCES page using the Right Arrow Key
Press the DOWN ARROW one time to select
Press the 1 button on your remote control
Press the 3 button on your remote control
Press the 8 button on your remote control
Press the 9 button on your remote control
The current Region Code Setting will display
Use the UP/DOWN Arrow Keys to select the region required or '0' for All Regions
Press the PLAY Button on the remote control
I bought mine tonight. The above procedure works perfectly. It is now set to 0, and I confirmed via firmware version page.
Cheers!
tip
Why Am I Unable To Program The RCA Remote Control To Operate My Components
Why am I unable to program the RCA remote control to operate a component? Why am I unable to program the RCA remote control to operate a component? If you are unable to program the remote control to operate a component, review the following information:
Compatibility
If none of the programming procedures work, the universal remote control may not be compatible with your components, based on the type of infrared technology and the age of the components. Some RCA universal remote controls will only work with components manufactured after 1990.
Distance
If you are testing the remote control after you have entered a code, you may be too far away from the component or you may not have the remote control aimed directly at the component. Because the remote control uses infrared (IR) technology to communicate with components, there must be an unobstructed path between the remote control and the IR sensor on the component.
Code Entry Methods
If the Direct Code Entry method was used to enter the codes for your brand and the unit is still not functioning properly, try one of the automatic code search methods instead. During automatic code search, the remote searches for the correct code to program.
Modes
For the remote control to know which component you wish to operate, you must put the remote control in the correct mode by pressing the corresponding component button.
Combo Units
To program the remote control to operate combo units, such as TV/VCR’s, TV/DVD’s, or TV/VCR/DVD’s, use the combo codes in the Code List to program the individual corresponding component buttons. Once programmed successfully, the TV button controls the TV functions on your unit, and the DVD or VCR button controls the DVD or VCR functions, respectively. The codes in the combo section should be tried first, using the Direct Code Entry method on the TV and DVD or VCR buttons. If this is unsuccessful, use one of the Code Search methods to program your combo unit.
Batteries
Make sure the batteries are new and properly installed.
2answers
Vcr recocognizing my remote.
Hi coldrh what remote controler aer you using?
Remote stopped functioning for dvd\vcr unit
When the remote control won't operate the DVD player recorder, check the batteries. Try replacing them and see if the remote works. If the batteries are fine, the code on the remote and the code on the DVD player recorder might not be the same. When aiming the remote at the unit a number will be displayed. To set the remote to the same number, which will be 1, 2, or 3, press down OK on the remote as the appropriate number at same time.
God bless you
6helpful
NEC NDT-40 DVD/VCR how to turn off "child lock"
on your remote down on the left hand side at the bottom of it its the second last button called c.lock its right above easy rpt press n hold till the little red key flashes and disapears off your unit !
1helpful
When I press the TV/VCR button on the remote, the picture on the TV becomes fuzzy and we see no signal from the DVD player. The first sign we were having trouble was that we couldn't set the time...
The TV/VCR button is usually not a function of a DVD player itself.
Normally this is a button on VCR remote controls that allow you to switch between whats playing in the VCR or whats coming in from the 'air/cable signal' from the cable or antenna wire on the back.
If this is a VCR/DVD player combo unit it would appear that the TV may be on the wrong channel for proper operation of the VCR functions (ch 3 or 4 are usually the selectable option on the back of the unit).
Make sure your DVD player is plugged into the correct input on the TV(video 1/svideo/or component ) and the TV is tuned to that same input. If the TV is on the correct input then the TV/VCR button shouldn't do anything at all which is normal operation when watching a DVD. If this doesn't clarify please reply with the model # of the unit. I would be happy to help more.
2helpful
MWD2205 remote stopped working for DVD functions
not sure but it sounds like you need to push the dvd button itself before dvd functions will work-it's to the left of the pause button. same thing happened to me and when i try that it works. remote seems to default to vcr i guess ....
9helpful
3answers
Vcr unit stuck in safe mode
Turn on unit. Press "lock" on remote (third from left bottom row.) Display on unit should say safe off.
28helpful
5answers
Stuck in "safe" mode
Hold down power on vcr/dvd unit or the remote for 8 seconds. It turns the SAFE mode on or off.
Top GoVideo Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
