Question about GE (PSS26MSRSS) Side by Side Refrigerator
Will not run
Side by side GE Profile with ice maker was running all the time - I turned off the freezer - waited 30 minutes and reset the temperature control. the motor/compressor never would start. any ideas?
  • 283 Answers
Unplug it for one minute and plug it back in. After a couple clicks it should kick in. If not there are tests you can do at the motherboard
Posted on Dec 30, 2007
I have a problem with a GE Profile PSS26PSSASS. The ice maker barely makes any ice. The ice that is made, is melting, dripping, creating icicles in the freezer, and then re-freezing in the ice bin as a...
Push the white paddle in three times slowly within 15 seconds. Then wait 2 minutes. You should see the ice maker start to cycle. If the ice maker doesn't cycle, replace the ice maker. If you need a new ice maker, you can go to the link below
Order Ice Maker
Refrigerator Parts
Feb 17, 2011 | GE PSSS3RGZSS Side by Side Refrigerator
Vegges frozen...ice in ice maker melting GE model PSW 26 LSRD refrigerator
Checkthe freezer temperature. The proper freezer temperature should be around 5degrees. The warmer it is in the freezer, the more difficult it is to make ice.
Jan 27, 2011 | GE Profile PSW26P Stainless Steel Side by...
Ice cube maker makes ice cubes ever once and a while, the condenser fan turns slowly. is this why it doesn't make ice cubes and the frezzer side is not cold enough? condenser fan going out? monogram...
Good day,
The ice maker speed of production is determined by the freezer temperature. If the freezer temperature is warmer than normal then the cycle thermostat in the ice maker will take longer to reset for the next harvest, causing low ice production.
More important, the condenser fan motor running too slowly can cause the compressor to run overheated and cause serious and expensive damage.
If in your opinion, it is running too slow, the issue should be addressed as soon as possible.
Aug 05, 2010 | GE Monogram ZISS480DRSS Stainless Steel
Ice maker is not working
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Mar 30, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
I have french door with freezer on the bottom refrigerator in the GE profile line. I have the internal ice cube maker. My ice cubes melt into one big block of ice. I lowered the thermostat to -5 but that...
check ur temperaTure in the freezer make sure it is 5 degrees fahrenheit or lower if it is u might need to see if ur ice maker tray has a crack i it to where when the water goes in to be frozen it runs out a crack and if all this is good check to see when the ice maker fills up its just not running over
Mar 01, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Nov 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Howling wind sound from the freezer/ice maker (extremely loud)
check the model # you post cannot find match there is a fan in the refrigerator section that some times make noise
Mar 25, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile TFT25 PR. Ice maker quit producing
Had the same problem. Replace the water filter and is should begin making ice again.
Mar 05, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
177 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
