Question about Sharp R-340 Microwave Oven
Location of monitor switch for Sharp R-5A54B microwave
The fuse blew on my Sharp R-5A54B. I replaced it and it blew again. The sticker next to the fuse says that when replacing a fuse you should also replace the monitor switch. Can someone tell me which of the three switches this is?
Thanks!
  • Anonymous Mar 26, 2014
    Fuse and monitor switch
The monitor switch is the middle switch. It is manufactured by omron and is a common type cherry switch. The omron part # is V-16G-2C25. The switch is a bottom type common terminal position with the contact form being a SPST-NC. Test the switch first with an OHM meter. Open the microwave door and you should have continuity between the two terminals. close the door and the continuity should be gone. P.S. The fuse may be purchased at any radio shack for about $3.00 pack of 4. their cataloge # is 270-1040 GOOD LUCK!!!!!!!!!!!
Posted on May 29, 2011
  • Sharp Master
  • 9,100 Answers
It's usually the one in the center, as opposed to the being near the top or bottom edge of the door.
The entire service manual is available for free download on the Sears parts site (page by page) at http://www3.sears.com/ (the 3 is correct)
Just look for the switch as ref # 1-7 on this diagram:
http://tinyurl.com/yqc9ol
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 31, 2007
Blown Fuse on a Sharp Microwave
I answered your dupe post here:
http://www.fixya.com/support/t26419783-replaced_blown_fuse_blew_again
Dec 30, 2016 | Sharp Microwave Ovens
Why does my Sharp Carousel convection microwave keep blowing fuses ?
I am wondering which fuse is blowing?
There are at least two fuses fitted internally and in the UK at least another fitted in the plug of the supply lead.
It isn't wise for an unqualified person to replace the internal fuses of a microwave even if it is switched off as there is a capacitor inside that is capable of storing a dangerous amount of energy.
The reasons why a fuse blows is either because there is a poor connection close by that is generating a lot of heat or the the fuse rating is incorrect or of the wrong type (quick-blow instead of slow-blow) or the appliance is consuming more current than it should be.
Microwave ovens have a fairly simple working principle and there aren't many things to go wrong. When things do start to go wrong or components become tired it is usually translated into a loss of efficiency that can be measured by how long it takes to boil a measured quantity of water, for instance.
Periodically timing a measured quantity of water to boiling point is a good way to monitor the performance of a microwave and when efficiency falls significantly take it to the service shop before something destroys itself and causes more damage.
In my limited experience the magnetron could be failing but the internals of a microwave should remain a mystery to the unqualified.
I hope this helps a little.
Jan 15, 2015 | Sharp Microwave Ovens
I have a sharp R-930AK micro/convection oven that blew fuse, replaced it, it came on then blew again. Help now what?
Hello, there is a component that is pulling more current than it needs to be. I would check the microwave HV diode there could be some leakage to ground. Also, the mega-tron tube might not be working the way it should. If the mega-tron tube is going out. Just replace the microwave oven. It is to cost prohibitive to replace the mega-tron.
If you replace the microwave oven. Please recycle your old microwave. Boy Scouts, recycling centers, some charitable organization will recycle. GB...stewbison
Sep 06, 2011 | Sharp R-930AK Convection/Microwave Oven
Dead, replaced fuse and it blew again.
The fuse is connected directly in series with the monitor switch. If it senses one of the door switches bad it will blow the fuse, this is there as an added safety to make sure the oven will not work without the door closed.
There are usually three and sometimes four door switches just inside and to the left of the control panel that are activated when the door interlocks with them. One of the switches is most likely bad. Typically it is the primary interlock which is on top. It can be checked with an ohmmeter, usually you can see it broken as the plunger will not go down or come up like the others.
May 10, 2010 | Maytag MMV1153A Microwave Oven
Monitor Switch Part Number?
They might be referring to a diode connected to the big silver capicitor and screwed to the case.
These can go short circuit causing the fuse to fail.
Mar 16, 2009 | Microwave Ovens
Sharp R-420AC microwave blown fuse.
Here is a link you or someone you know can use to test it, but please read the safety info:
http://www.gallawa.com/microtech/cap_test.html
The best place to order parts for this brand is Encompass (formerly Tritronics).
Or you can call them toll-free at 866-779-5835.
Jan 04, 2009 | Sharp R-340 Microwave Oven
Sharp Model 1451 blown power fuse
1.Problem with monitor door switch or
2. Problem with high voltage condenser.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Nov 30, 2008 | Sharp R-1874 Convection/Microwave Oven
Microwave blew up after cooking an egg
Yes the internal fuse will have blown. I would also think the door latch switches and monitor switch will also need re adjustment
Jul 08, 2007 | Sharp R-408J Microwave Oven
Blowing fuse problems
The door latch switches, and monitor switch assembly needs adjusting. With the door open the two latch switches should be normally open,and the monitor switch closed. Opposite way when door is closed. MAKE sure oven is unplugged before testing
Jun 28, 2007 | Daewoo KOR-860A Microwave Oven
Sharp R-340 Microwave Oven Logo
821 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
