Question about Samsung HP-S5053 Television
Samsung HP S5053 Static / Grainy Image
Hi, I have had my Samsung S5053 for about a year and a half (and I have the Best Buy extended warranty). For about the first year, the picture was FLAWLESS. Now, when I turn the TV on, the picture is filled with Static for a while, and then all of a sudden, the picture corrects, and it's perfect again. I've changed some components in the past year, and added a Monster PowerBar (model 1100 I believe). It doesn't seem to have to do with my input (TivoHD), as the picture problem doesn't get solved by switching to DVD. Any solutions or suggestions?
  • LeeSchneider Dec 31, 2007
    I should also add that there is a "humming" noise that has gotten louder as well. seems to be coming out of the top of the TV, where the air vents are.
  • LeeSchneider Jan 01, 2008
    Thanks. Just to be clear, those settings are inside the back of the TV, not on the Monster Power Strip, correct?
  • 106 Answers
Try to adjust the Vscan or/and Vs down about 5-10V on the Power Supply board. If you got extended warranty, just let the warranty depot shop help you to do it.
For the "humming" noise, may need to replace the Power Supply board to fix it.
Posted on Jan 01, 2008
Samsung hp-s5053 bottom half goes black intermittently. Picture is fine, bottom half goes black, then picture comes back. Is there a replacement part I can try before disposal?
The Tcon board or the LCD panel is faulty. Can confirm by replace the Tcon board .
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jul 02, 2016 | Samsung Televison & Video
Samsung hp-s5053 picture goes black
Check settings in menu for correctness. Change input device to something you know works for sure. If problem persists, it might need attention by a qualified service technician.
Jul 22, 2012 | Samsung HP-S5053 Television
Hi, After 4 years long, my Plasma decided to have some blinking black the top half of the screen after watching tv for 10 min. Can you please point me to the right direction on what to replace? Many...
The first thing I would do if it were mine (and I'm a tech) and had those symptoms would be to clean the ribbon cables coming from the upper Y drive board. That's the skinny one on the left side to the left of the Y main. Be careful, if you damage the ribbon then you throw the set out. If that doesn't cure it then you can look at the Y Main. There are some small silver tin-can type capacitors towards the top that quite often go bad. If you have a cap checker that will make it a whole lot easier and faster. I can't see replacing the whole board for a few bad parts.
Dec 27, 2010 | Samsung HP-S5053 Television
Hi, My Samsung hp s5053 plasma is broke anyone can help me please!
A TV repair shop is your best bet - the problem is likely the power supply - check the fuse.
Dec 04, 2010 | Samsung HP-S5053 Television
Hp-s5053 samsung plasma with snow on hd content
It appears that the Main bd is bad. Try using Component cables instead of the HDMI cables and see if there is a change. If there is a change to normal picture then try another HDMI cable. If the problem returns then replace the Main bd. There three Main bds for this basic model number. You will need the version# found on the right side of the set to order the correct bd.
Jul 16, 2009 | Samsung HP-S5053 Television
Blank Screen but sound works on samsung HPS-S5053
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
Jul 14, 2009 | Samsung HP-S5053 Television
Top half of screen going black.
I've seen this or something similar to this problem on an old lcd screen. The bulb haden't burned out but the system was no longer getting proper 5 volts to the processor chip that processed the image. I ended up desoldering the voltage regulator and soldering a new regulator in it's place it was one with the same amperage so I put a heatsink on it to reduce the chance of another failure.
Feb 16, 2009 | Samsung HP-S5053 Television
Flickering screen with semi-circular middle whitish flicker and static sound
Use your warranty, as most warranties are vioded if you open the set up.
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Image is grainy whenever tv is cold
try having the v_set and v_scan voltages reset 15vdc lower..
Nov 02, 2007 | Samsung HP-S5053 Television
Image is grany every time tv is cold.
I had the same problem. Except mine never got better after the tv warmed up. I fortunately I still have my manufacturers warranty and Samsung sent a guy out within a few days. He replaced a few parts which really didn't do anything. However what he did that was interesting was on two circuit boards. One on the mid left and the other on the mid right. Apparently there is a nob or something he tweaked on each panel that cleared the grainy image right up. What he told me was that the it is basically pixels that are not turning off in sync. adjusting the two circuit boards syncs the pixels to turn on and off at the same time.
Nov 02, 2007 | Samsung HP-R5072 50 in. Plasma HDTV
Televison & Video Logo
475 people viewed this question
Jerry Greenberg
Jerry Greenberg
