Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Dyson dc07 motor sparks
recently the belt snapped so replaced with new dyson belt, now since i fitted it the rollers turn as normal but straight away lots of sparks are coming from the motor so i cannot use, any ideas could this be the actual motor or maybe the bushes.
thanks
have owned for aprox 3 years its the yellow/steel dyson
  • 372 Answers
Hi.
I think you are looking at replacing the motor with a new one.
http://dysonmanuals.llc.nu/
Chris..
Posted on Dec 30, 2007
Dyson model DC07 the belt controlling the beater bar is not turning but does have tension
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dc07
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Dec 09, 2016 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Brush won't turn on dyson dc07
There was a belt that was to be attached to the motor shaft under the belt cover, be sure that it didn't pop off. the recommended fix is to replace the clutch, not the belts in the clutch. if you only replaced the belts it could still be a bad clutch.
If you need any help feel free to contact me.
Tim
TheVacCenter.com
Feb 16, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do you change a belt on a dyson DC07
Turn vacuum over so you can see the brush.
Using a standard screwdriver, undo the three fasteners just behind the brush.
Remove the base plate.
Remove the belt.
Remove roller brush.
Place new belt on roller brush and center it in position.
Feed belt through the hole, and return brush to position.
Ensure the brush ends are located in the slots correctly.
Pull the belt over the motor shaft.
Rotate the brush a few times to ensure belt is centered and secure.
Replace the base plate, tighten fasteners, and rotate the brush a few more times to make sure it turns properly and the belt isn't caught.
Mar 04, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I recently replaced the motor belt on my DC07 and now there is a very loud noice coming out of it when in use. What could be the problem?
Hi there SmartAlec here. I am guessing that since you said you replaced the belt on your vacuum that it was actually really stretched or broken before. Assuming this is right I would say that either the clutch roller is actually faulty or there is a problem in the bearings of your brush roller. I have made a video to show you how to look for these problems. If you need parts for your Dyson DC07 check out vacuumspot or nelsonvacuums they both have a good range of dyson spares for purchase online. If this guide was helpful please take the time to leave a review of give it a thumbs up!.
Aug 20, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a dyson root cyclone. i dismantled it to replace the belt, it is not the belt which is on the roller brush, it is the belt which is from the motor, it was easy to take out as it was broken, i will...
The belt that fits on the motor is the same belt that drives the roller brush, all you need do to gain access is remove the sole plate, normally attached with 3 quarter turn connectors, use large flat screwdriver to turn them
Apr 15, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Have a dyson dc07 -roller bar broken. have
It always feels like something must break as it's a really tight fit, but go to www.dysonmedic.com then scroll to the bottom of the page and click on DC07 belt and brushroll replacement guide. You'll find everything you need there. Good luck!
Jan 24, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
The roller in the vacuum head no longer spins
If the motor is running but the roller is not turning you need a new drive belt and if you are in UK you can order it from http://www.dyson.co.uk
it is very simple to fit and comes with full fitting instructions delivered for about £6.
Please leave a positive feedback if I have helped you.
Thanks
Aug 09, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 brush roller is worn and won't make contact with the carpet anymore. I need to replace the brush roller but don't know how...HELP?
Buy the brush over the web etc..
To take the brush out
1 - Take the outer covering - uese a penny to turn the yellow srews
2 - Slide the black brush out from the assembly - Try the non belt side first.
3- Slide the belt out of the brush.
4 - Take brush out - Replace it with new one.
May 09, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
Dyson DC07
Hi.
Depending on wether your machine has A clutch fitted will decide how easy this job will be.
The non clutched model is very simple turn the 3 plastic screws on sole plate to unlock position lift plate off remove belt from motor shaft & lift out brush roller.
Replace belt & roller fit sole plate & its done.
The clutched version will require the removing of the sole pate,
Then remove brush roller. & brush roller housing.
Then remove clutch cover,
Replace both belts & reassemble.
Its A lot to explain in great detail so try this site if your struggling.
Jun 18, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
611 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
