Question about GE DBSR453EBWW Electric Dryer
Ge dryer shuts off
I have an older model GE electric dryer, it runs for about 5 seconds and then shuts off. I already check for lint cloggage. My dryer is very old and don't have many sensors etc....
  • Mantman Dec 31, 2007
    The drum turns easy, when I press the on button the dryer starts like normal then immediately shuts down
  • 1,314 Answers
Turn the drum by hand see if it turns fairly easy if it does then you may need to replace or clean the drive motor if not may need to service the tub rear bearing tub glides etc
Posted on Dec 30, 2007
  • robert samples Dec 31, 2007
    you need to clean the motor if that doesnt fix it you will have to replace the motor
My GE dryer GFDN110EL0WW when turned on runs for 5 sec. Then cuts out after about 15 secs. It will automatically start again. And will continue this cycle until I turn the unit off.
Dear Kevin.
I surely hope you do not already know this!
Dryers today have a whole bunch of shut-offs.
Specifically, a fuse or two and several thermostats, any of which will cause your symptoms.
The most likely cause is air tubes clogged with lint, which the lint trap does not catch.
The fix should be to take the whole machine apart and clean the whole thing.
You may find as much as a shoe-box full of lint inside.
That lint has caused one of the fuses or thermostats to shut off the machine before it catches fire.
God bless your efforts.
Jul 30, 2017 | GE Dryers
Dryer starts but after a few seconds shuts down
In the last 6 months, I have fixed 3 dryers with your symptoms. In each case, after taking the dryer completely apart, I found it plugged up with a huge amount of lint. This lint was not caught by the filter screen, it had collected all over the inside of the machine. It required dismantling the machine completely to clean,. Each dryer then worked fine.
Be blessed.
Jan 03, 2014 | General Electric Profile DPVH880GJMG 7.5...
Our LG DLE0442W electric dryer is now flashing the Check Filter light and will start, but only run for about 5 minutes before shutting off. I have cleaned the lint trap completely and have also tried...
Clean any lint that got by the filter as best you can. If you can, get into the housing that surrounds the filter and clean it, but be careful not to damage the moisture sensor.
Check that the duct (behind the dryer) is clear of excess lint and has no obstructions (kink, bird's nest, etc.).
Good luck
Feb 21, 2011 | LG DLE0442 Electric Dryer
Lint filter light goes on; vent unattached so no blockage and lint screen is clean. Thermostat? Temperature regulator? Model 3510 - about 6 plus years old
Thanks for using FixYa. To start with the first thing you should do is to remove the lint filter and clean the lint out of inside where the lint screen goes, I mean if you have not done this already. After this unplug the unit for 5-10 minutes and then push & hold the start/pause button for 10-15 seconds and reconnect the unit. If still it won’t work then it’s the Thermal fuse that has gone bad and needs to be replaced. Please do accept the solution if the issue is resolved or else revert for further assistance.
Aug 15, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Ge gas dryer doesnt dry, I have cleaned lint screen and ducting is clean and straight. clothes are damp after two hours run time, so the sensor seems to be okay or atleast it knows the clothes arent dry.
How old is this dryer? The older ones would do this when the vent was clogged with lint near the outside exhaust area, or if the belt is worn or stretched. (this allows too much heat inside the dryer at one time, and forces the unit to shut down to prevent a fire hazard)
Jun 22, 2010 | Dryers
Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Jun 21, 2009 | Dryers
Maytag MDG4806AWW Runs for 5 to 10 seconds and then shuts off
This is kind of unusual esp. on a newer model. Sounds like it could be the signal from the thermostat to the motor could be bad. The timer may be faulty especially since you replaced the motor.
Nov 18, 2008 | Whirlpool LER4634J Electric Dryer
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
It starts and runs for about 20 - 30 secondds then stops
Pwolf, looks like the problem you?re having is not with the dryer. The vent line is probably clogged up, which caused the dryer to overheat. The hi limit thermostat opens up which shuts off the dryer. After it cools down and closes, you are able to restart the dryer. To make sure this is a vent problem, you can disconnect the vent hose behind the dryer and run it for one load with it disconnected. If it runs fine, then the vent line needs cleaning. Usually it needs special equipment and is very hard to do yourself. It would cost you around $90 to get a professional out to do it for you. If it doesn?t run with the hose disconnected, then you have to provide the complete model number, which is located on the door frame. back.
Dec 14, 2006 | Kenmore 64852 Electric Dryer
GE DBSR453EBWW Electric Dryer Logo
274 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
