Samsung SAMTRON 55V  15 in.CRT Conventional Monitor
Problem for Samsung SAMTRON 55V (White) 15 in.CRT Conventional Monitor
My monitor screen get pinkish , and its get
By abhishek_ch0 on Oct 23, 2009
my monitor screen get pinkish , and its get automatically to normal but its not permanent . whats d problem
Best Solution
posted on Oct 24, 2009
Very Helpful)
bhagyavichar
Rank: Guru  Computer Hardware  Expert
Rating: 95%, 2478 votes
i gotta know if ur monitor is crt or lcd??
if lcd, Geekman's solution sounds good....
but for crt, u gotta look for dry souldering esp at the crt base..also check the resistances, good heater pin contact, the crt base therein..beware u shld b a professional !!
Was this helpful?
Yes
No
24 people thought this was helpful
Solution #2
posted on Oct 23, 2009
Somewhat Helpful)
Geekman
Rank: Guru  Samsung Computer Hardware  Expert
Rating: 85%, 1851 votes
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Was this helpful?
Yes
No
Popular Solutions for Samsung SAMTRON 55V 15 in.CRT
Questions and Unsolved Problems for Samsung SAMTRON 55V 15 in.CRT
Do you recommend Samsung SAMTRON 55V (White) 15 in.CRT Conventional Monitor?
Answer
Answer
when i switch on my monitor its color become yellow, but when i slightly move the vga cable of... (More)
Answer
samtron 56v power supply generate chirping sound in 1 sec interva and no secondry output
Answer
I am trying to use my Samtron 73V monitor as an extended desktop with my Toshiba P220D-139 laptop.... (More)
Answer
PLS Help ME.MY PROBLEM SOFT. ANY MESSAGE BY MAIL ACC.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
in , CA
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
