Adcom input jack replacement
The input jacks on my Adcom GFA-555 are broken off. How do I replace them myself. Thanks, Robert.
    Scholar:
  • 54 Answers
The input jacks on a 555 are a standard gold plated, high quality jack. looking around the net, you should pay no more than 7-10 dollars each ( or just get originals from Adcom. ). What is your comfort level with electronics?. Can you solder properly?. I cant answer this without more info.....thanks...Good luck...Rob
Posted on Mar 03, 2008
Can I run two stereo amps from same preamp?
yes, and do tell, what speakers are you powering with these amps?
Jul 09, 2013 | Bose 901 EQ1915 Home Equalizer
Bridge adcom gfa-5500
not unless it has a Bridge switch OR you design an inverter circuit for one of the inputs. If it has XLR inputs you can try to invert pins 2 & 3 on one of them, that might work...
Aug 12, 2012 | Adcom GFA-5500 2-Channel Amplifier
I have an Adcom GFA 555 type II that won't shut off when the power switch is turned off...I'm assuming a relay problem?
please replace power switch to solve amplifier problem as power switch internal contacts seems stuck and does not disengage to turn power Off.
Thanks.
Mar 19, 2011 | Adcom GFA555 Amplifier
On the inside back wall of the 1986 Adcom GFA-555 Stereo Power Amplifier there are four fuses,two for each channel. Would you tell me please, what amp fuse they are and if they are the fast or slo-blow...
Sorry to contact you this way but i've spoken to an older colleague of mine and it appears that before 1992 in the Adcom GFA-555 they were using bipolar transistors and the amp was rated fo a minimal impedance of 4 ohms - not like in the newer ones that have MOSFETs and are rated for 1 ohm in bridge mode. So the fast fuses that you need are of 6 amps , not 20 like in the newer models.
Sorry for my mistake.
Jul 11, 2010 | Audio Players & Recorders
Adcom gfa 555 blows the 10 amp fuse and the 6 amp fuse on the far right
Any fuse blowing is caused by a shorted component in either the power supply section or main audio amp part. Follow the fuse circuit and see where it leads you. Look around for burnt of damaged parts. Suspect anything sitting on a heat sink. The most common culprit is the audio amp main transistors, especially if someone shorted the speaker leads together. In the power part it could be the transformer, the large Electrolytic capacitors, rectifier, or voltage regulator. Some amps use an IC for amplification and this can blow the fuse.
Oct 19, 2009 | Adcom GFA-5500 2-Channel Amplifier
Adcom 7500, Adcom 5400(bi-amp), Marantz AV-9000, Dakiom HA103
Try just the power amp on ..nothing connected
no Dakiom thingy either. It's a matter of elimination. Start at the output device and work back. Keep the Dakiom out of the loop.
If there's hum with just the Adcom..then it's the ADCOM
Mar 25, 2009 | Adcom GFA-7500 5-Channel Amplifier
How to bridge GPA 555 adcom amp from 8 om to 4 om
First of all, when bridging an anp, the impenence that it can handle usually goes UP not down. I don't believe that the GPA555 can be bridged without circuit modification.
Dan
Feb 11, 2009 | Adcom GFA-5400 2-Channel Amplifier
176 people viewed this question
 Grubhead
Grubhead
