Question about Dryers
Kenmore gas dryer
The drum inside has stopped spinning the load everything else works the same.
  • 283 Answers
Most likely the belt broke. Part number 341241, dont destroy the bag it has installation instructions on it. While you have it apart clean the lint out
Posted on Dec 30, 2007
Propane Kenmore front loader dryer drum won't stop spinning and there's no heat.
EITHER OUT GOT A BAD DOOR SWITCH AN. BAD PART THAT CONTROL THE GAS TO YOUR DRYER BUT SEND THIS IS A PROPANE GAS DRYER IF U NEVER WORK ON ONE IT BE BETTER FOR U AN YOUR FAMILY SAFE TO CALLL FOR SERVICE
Apr 03, 2015 | Kenmore Dryers
Kenmore model 110.63942101 (electric). everything works but no heat... drum spins, timer works. Should I buy heating element replacement kit? does it need to be installed from the back of the dryer...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 19, 2011 | Kenmore Dryers
My kenmore dryer heat very good but the drum stop working it dose not spin at all
Hello
The drum not spinning is either a broken belt or a faulty drum motor.
Mar 21, 2010 | Kenmore 73952 Gas Dryer
Drum will not spin. The belt is not broken but is hanging lose
If the motor is working...Shut off the power to the dryer, reach inside the drum and try to rotate the drum 1/4-1/2 turn. Sometimes the motors get dead zones in them and this will help move it out of the dead zone
It could also be the drum rollers that need lubrication or replacement, if they are not rotating it would not allow the drum to spin.
I hope this helps
Oct 02, 2009 | Kenmore 73952 Gas Dryer
Excessive noise/vibration
Vibration problem occurs on dryer/washers because of bad dampers generally. When drum is loaded, the load is distributed randomly, so its create vibration when drum spin in certain revolution. The dampers are supposed to take this vibration and minimize them.
There are more possibilities like drum dislocation or bended drum etc.
Jun 28, 2009 | Kenmore 73932 Gas Dryer
Dryer will not start, just humms
sounds like the drum belt maybe broken or worn out.
May 25, 2009 | Kenmore 98702 Stacked Washer/Dryer
Noisy dryer Kenmore Elite 70892 (gas-LP)..
OK, Kenmore,.... I don't work on many of them, but,....
Disconnect power. You have to lift the top to gain access to the screws near the top which hold the front panel to the sides. If it has a top lint filter, you will most likely have to remove the screws holding that to the top, then use a putty knife to release the spring clips at the top of the front panel. Sounds like the blower wheel is spinning freely on the motor shaft, requiring replacement of blower wheel.
Sep 06, 2008 | Dryers
Dryers Logo
57 people viewed this question
Top Dryers Experts
Marvin
Marvin
