Question about Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso
Espresso won't brew
I tried brewing a single espresso pod in the filter that came with the machine and was placed in the porta filter. The machine was turned on and no coffee brewed, just water came out.
  • 1 more comment
  • Richie Winte Dec 17, 2008
    at least water came out of yours.  Manufactured in China using kiddie labour and no quality controls.
    Krups = Krap
  • paony Mar 19, 2009
    i have xp 2070 it can used a few months . now it not work . it bad quality.
  • Anonymous Mar 19, 2014
    The kind of pods that are made out of filter paper, not the plastic "Keurig" types.
    New Friend:
  • 39 Answers
The only way to get hot water via the espresso filter without coffee will be due to using the wrong size filter holder forthe pod. The machine comes with three filter sizes for pod, single and double espressos. This could be a simple issue of using the right filter holder.
Posted on Dec 31, 2009
Same prob
Posted on Apr 23, 2008
Try cleaning both exit needles. Make sure to also clean the area around the pod holder if there are any coffee grounds and dirt. When you put everything back, fill the tank with fresh water and run few brew cycles without inserting the pod to rinse the machine.
Also, do not use softened water because it can cause problems, especially if you use Keurig. Filtered, tap or bottled water is a better option.
Feb 18, 2018 | Coffee Makers & Espresso Machines
The grinder works but coffee too light in colour and no foam
You didn't indicate what model you are using but it could be several things.
If your coffee isn't ground fine enough your brewing time may be too short. Your double espresso shot should take between 18-26 seconds to brew. A single should take between 9-13 seconds to brew.
If you are getting the correct brew time, try a different coffee bean. Some coffee is roasted more that others and that could be the reason the color is light. Make sure you are using fresh beans too.
Make sure you are putting the correct amount of ground coffee into the porto filter and tamping it well. A porto filter that isn't full will not brew a good shot.
Sep 22, 2016 | Faema Coffee Makers & Espresso Machines
How do I fix the water pump of a delonghi BC4264B? It's not pumping any water to make espresso. the machine heats up well, the steamer works fine, the drip brew side works fine. I'm not getting any...
Is there any water coming out of the group head when the porta filter is not used???the group head has a filter on it and it could be totally clogged
Jun 11, 2014 | DeLonghi DE500P Dehumidifier
Verismo 801
Sounds like a problem with the pods. Check they are manufacture recommended. When on espresso the pressure will be higher so a
"weak" pod could cause this. Unless the machine is producing too high a pressure. Check also there are no projections that could rip the pod when you close the holder.
Jan 28, 2014 | Coffee Makers & Espresso Machines
My Breville Keurig won't brew the coffee
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
May 31, 2010 | Breville BKC600XL Coffee Maker
Gaggia syncrony logic not dispensing water. Just drops pods and red light comes on. have cleaned brew unit shower screen and dispenser tube. still have the problem
Lubricate the brew unit with a food safe grease this should help.
The brew unit becomes stiff and fail to load up fully this stops the water being dispensed
Jan 18, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Water pours out from all around when making coffee. I fill the filter with coffee and turn the machine to brew and water seems to overfill and comes out over the top.
Theres a seal from the machine to the handle or porta filter its acalled a group seal it is worn or dried up solution is to replace the seal
Dec 16, 2009 | Breville ESP8XL Espresso Machine
I have the Keurig Gourmet Deluxe Home Brewing System #B60 When the pod is in place with the cover down the water won't come out while brewing. It will not make a brewed cup of coffee. If I remove the pod...
Check that pod has a punctured hole on BOTH ends.. If the bottom or to wear not punctured this will happen with most Keurigs.
Replace the pod holder if defective.
May 18, 2017 | Keurig Coffee Makers & Espresso Machines
Unit will not brew when pod is inserted; works w/o pod however.
This may be one of two issues:
1. The pump is malfunctioning which can cause the internal reservior to not completely fill which causes issues during brewing. My unit dribbled random amounts of water instead of brewing for about a week before the pump died completely.
2. The puncture seal isn't in the right position. Open the Keurig fully so you can see the sharp puncture pin. Very Carefully push the black rubber gasket around it all the way up. Then pull it back down about 1/16". Brew a cup, if the problem continues, try sliding the gasket further down by increments of 1/32".
May 29, 2009 | Keurig Ultra In Home Single Cup Brewer...
Not making espresso from beans
Are your coffee grinds wet? If they are you have a clogged brew head. Remove the filter screen. Then remove the 2 screws that hold the outlet manifold to the brew head. There are 3 things under the manifold. O-ring, tapered spring and a crystal ball. Don't lose any of these items. Now to clean the brew head turn the brew unit over to where you can see where the brew screen was. You will see 2 holes, 1 large and 1 small. Take a paper clip and straighten it. Turn the brew unit upside down and insert the paperclip into the small hole. Push the paper clip through and remove the plug. I have seen them over 1/2" long. Reassemble the brew unit crystal ball first, small end of the spring on top of the crystal ball, place the o-ring over the spring and place the manifold on top making sure the outlet pipe is to the outside of the brew unit. Put the 2 screws back and your ready to go. Run a detergent for espresso machines like Cafiza through the brew unit every once in a while to keep it clean. It doesn't take a lot of detergent and use the pre-grind setting and a large cup selection but don't put any coffee in.
Nov 25, 2008 | Saeco Royal Digital Plus Coffee...
Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso Logo
512 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
