Question about Sony PlayStation 2 (PS2) Console
Disk read i have an older version ps 2 and it wont read some disk in silver format but will read others, am i ok to use a phillips brand dvd laser lens cleaner
    Problem Solver:
  • 18 Answers
This may be caused by the discs you are trying to read are Dual-Layer format DVD's. Your best bet would be to get in contact with Sony.
Posted on Dec 31, 2007
Why is my dvd player always saying wrong disc
When it says wrong disk there must be a reason why. To test the system, you should put in a bought DVD, not one you burned yourself on the computer. If that DVD does not give a message, you know the player is 100%.
What could be wrong with self made disks?
First a normal DVD has a silver or gold layer to reflect the light coming from the laser. A disk you can burn yourself, has a dye, which changes colour when the laser burns its info. It ls less and less reflective, compared with the silver or gold plated ones.
Then when you have burned the DVD's from your computer, with a video format, other then the DVD format, most DVD players can't play that. There is only one DVD format and there are hundreds or different (not with DVD compatible) video formats, you can play on computer and MP4 players.
I hope this is enough info for now.
Apr 19, 2015 | Spectroniq PDV-70X
Ps2 wont read discs and asks for format disc
I can guess that the games you are trying to play have a Blue underneath and not silver. This was a big problem with my sons disks too using the older version of the ps2. We managed to mess about with some of the settings and changed the rgb setting to the other option (can't remember what that was now...sorry) and got some of them to work, but not for long. When the new games come out now they expect you to have the slimline ps2 and unfortunalty won't work on the older model. So to fix this problem I just bought a new one.
Oct 26, 2008 | Sony PlayStation 2 (PS2) Console
Will play CD's but not DVD's or Games
You have to take the box apart and clean the lens.Ok !
  1. The white plastic gear that moves the laser must make contact with the "motor". A bad contact here can cause disk read errors. Sometimes it looks Ok, but you may need to remove the lens and bend the white gear for good contact.
  2. The two rails on which the lens move must be very slippery - which can be lubricated with cooking or motor oil. Usually the holes where the rail is (on the right side of the lens) are dirty or you have to bore then out slightly, making the holes bigger.
  3. The lens uses little torx screw (black) that move the lens up and down on the rail. Usually the lens is too high and requires adjustment.
  4. Take the lens off these 2 rails and take the black plastic cover off. Turn the lense upside-down and you'll find there are 2 screws (silver, phillips or torx) that you have to remove to take the upper little lens off.
  5. Then you'll see a larger lens that is usually very dirty (this lens is a mirror to light). If that's dirty, it will give a disk read error. You'll have to take the little electric board off that you see on the other side of the big lens-mirror. It's probably dirty too, so clean it. Alcohol should work OK for this task.
  6. The lens bottom has 2 + 2 screws. You move the upper "little" lens up-down-left-right (this may require a special screwdriver)
  7. The motor "rail" that moves the lens must be very clean and oiled and the 2 rails too.
Jun 06, 2008 | Sony PlayStation 2 (PS2) Console
Ps2
Is it all of your disks or just that one? If it is just one disk then you should try and clean the disk. If it is all of the disks then you may have a dirty laser eye and need to get a dvd cleaner, I personally recommend the phillips brand dvd cleaning kit. It should be a disk cleaner and a cd/dvd cleaning system for the laser eye. It usually runs under 15 dollars. If this doesnt work then your system is shot and you should replace it.
Mar 28, 2008 | Sony PlayStation 2 (PS2) Console
Can't Read DVD Games.
Your laser needs to be adjusted Inside the PS2 there is a white wheel that can adjust the laser up and down to find it's sweet spot for reading all types of disks. It's also possible something is wrong with the laser and it needs to be replaced.
Mar 03, 2008 | Sony PlayStation 2 (PS2) Console
Lee playstaytion two
Hi Lee,
Your lasers on the way out.
it,s all to do with the power output of the laser head, and the angle for reading the 2 different disk types.
i,d suggest getting a new laser fitted. not too expensive usually with older consoles. Try E-Bay :)
Mike @ Compurepair.
Feb 18, 2008 | Sony PlayStation 2 (PS2) Console
PS" Version 12
check to make sure flat cable that connects laser is installed correctly or isnt damaged.
Jan 09, 2008 | Sony PlayStation 2 Slimline Console
Can't record
hi all, spanky new, ok here my problem!! i got the panasonicdmr-e55 for xmas, 3 or 4 years ago. since then and even wheni started to use it the disc i recorded on were -R phillips 4x. since then i have tried every available manufacture of 4x's u could think of and yet to this day it will only record on a phillips 4x disc. its been in the shop a few times for cleaning and upgrades and yet they haven't beable to tell why it only accepts PHILLIPS BRAND 4X. the new upgrade i recieved fromthe manufacture was supposed allow higher in x's on disc. it accepted 16x phillips only ONE TIME AND REJECTED 50 OF THEM, SINCE THEN ABSOLUTELY NO MORE 16X OF ANY KIND. ANYONE GOT A SOLUTION????? ps even tried 8x its still a no go. i can't afford anything since i'm on social security. message: UNREADABLE DISC. SUGGEST REPLACED DISC. OK SO THIS MORNING I TRIED TDK, MEMOREX, H.P. CIRCUIT CITY, AND 6 OTHER BRANDS ALL 4X NEGATIVE R, STILL A NO GO HELP, THANKS GINA
Dec 23, 2007 | Panasonic DMR-E55 DVD Recorder
PS2 Slim does not read disk
Check this Solutions,
Check temp of console, if ok continue:
Check the disc is Scratch, if ok continue:
Check the Laser is funcion, try a dvd, cd or ps1 game, if ok continue:
Check the Laser aligning up.
Dec 12, 2007 | Sony PlayStation 2 (PS2) Console
Playstation2 not working properly
Hi there. Are the older games you're trying to play CD games ? They might be :) The laser lens in such consoles can be fried on the dvd part, but still read CD's. Have you tried, to read a DVD Movie in it ? I bet it doesn't work either. The slimlines are infamous for laser burnout, and god they're quick to burn. You can try to clean your laser lens with a q-tip and some rubbing alcohol, but i'd say you're already out of luck. The optical lens is quite easy to replace in those units. They can be found on ebay and on various websites for 20$, and if you can play a bit with a phillips screwdriver, chances you'll be able to replace it yourself with a bit of patience are good enough. If you need additional help just ask, hope that helps ! cheebster.
Jun 09, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 (PS2) Console Logo
48 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
