Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Magnavox 60'' rear projection screen tv
I started to try to fix my own tv. The picture wasn't coming in clear, so i looked into the color lamps. The green and blue looked dirty, so i took them apart to get the dust out. when i took the lens off, a whole lot of oil came out. I cleaned all of the dirt looking stuff out. My question is , what kind of oil do i put back and how full?
Thanks,
James
  • pumkineatter Jan 06, 2008
    I have the same proble and I dont understand when you said I hope you only removed one tube. Can you explain. I plan on getting me some glycol and replacing the fluid in all the lamps.
  • 373 Answers
That oil is glycol and is a coolant for the tube. Hope you didn't get the oil on the circuits because it is conductive and the tv will not operate with the oil on it. Must be completely full. Can be bought a electronic parts distributors or a tv shop could order you a bottle. Hope you just removed one tube only. Make sure you seal it back good
Posted on Dec 30, 2007
I have a 60" rear projection tv and the picture looks like its missing a color the picture isnt distorted or anything but the colors are bad what could be the cause and the fix
sounds like a Phillips or magnavox that has bad CRT coolant which needs replacement. If so you can get the Phillips CRT coolant repair kit from www.tvrepairworld.com it comes with instructions and the coolant for all three CRts,
Mar 01, 2013 | Televison & Video
I have a Philips Magnavox 9P6034C 60 in. Rear Projection Television the whit bulb is gone out where do i get another one
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 27, 2011 | Philips Magnavox 9P6034C 60" Rear...
Magnavox PTV910. The picture is good but color is bad
the coolant in the blue and green crts has congealed which is causing the red tube to become dominate. The coolant can be changed at home. You can get the phillips coolant replacement kit at the following link which contains the coolant and the CD with instructions.
http://www.tvrepairworld.com/
Jul 15, 2009 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox 60 inch Projection Tv
That model is famous for having bacterial contamination in the CRT coolant causeing halos, and dim pictures with bad overall color issues. You can look into the lens of the CRTs when the set is laying and if the coolant looks cloudy or has any growth there you will notice it right away, and changing the coolant will restore color, clarity and brightness.
Jun 15, 2008 | Philips Magnavox 9P6034C 60" Rear...
My Philips Magnavox 9P5511C102 color is faded and not clear. The colors seem faded (off) tv is not clear, like is got static, and picture is shaky. I have tried to fix using the Main Menu already. Out of...
update the firmware/software if possible. my 60" has a USB slot on the right side. also you can download the manual from phillips http://www.support.philips.com/support/html/index_us_en.html#../~scripts/xsltransform.asp?url=http://www.sms.philips.com/catalogue/list?sid=SMS||type=CONSUMER||locale=us_en||mode=cats||item=TV_GR&xsl=subcatalog.xsl
my phillips 60PP9200D/37
Apr 26, 2008 | Philips Magnavox 9P6034C 60" Rear...
60" Projection - Screen shrinks down then back up
I had the exact same problem. The screen would shrink then expand. After thrity minutes it would correct itself. Then one day it just broke - no sound and no video. I searched these forums but did not find clear instructions on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.  To help others like me I documented the fix and created a step by quide and repair kit to fix the problem. You can find it here. http://www.magnavoxhelp.com
Jan 19, 2008 | Philips Magnavox 55P9271 55" Rear...
Picture gradually got darker and less clairity
the lamps have to come out. the fluid has to be sucked out from the bottem.
Jan 05, 2008 | Philips Magnavox 9P6034C 60" Rear...
51 projection tv dark colors
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 20, 2007 | Philips Magnavox 51MP392H Rear Projection...
Blue (actual) lamp out of focus. Picture is washed out and milky.
I found a local tv repair guy who sold me the the CRT fluid for $80 and I gave it a go. It wasn't easy, but it worked. If you are really interested I'll tell you how I did it.
Aug 11, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 60PP9701 60 in. Rear
If the picture is changing size when bright images appear on screen, then a power regulator issue is what you have. Have a technician look at it.
Feb 23, 2007 | Philips Magnavox 60PP9701 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
133 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
