Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Need to find the main run and ground wires
Am fitting a side number plate
  • 27 Answers
What year and model?
Posted on May 23, 2008
My rear wiper, defroster and licence plate lights stopped working on my 2007 suzuki swift but when I open the rear hatch the licence plate lights come on . Any ideas what's wrong?bad ground?
[PDF]Wiring Diagram.pdf - Ken Gilbert
ken-gilbert.com/wrx/mans/99.../Wiring%20Diagram.pdf
Each connector number shown in the wiring dia- ... Rear defogger cord (Ground). Fuel tank cord,. Roof cord, ... circuit. Then check the switch, relay, fuse, ground, etc. 4. .....Rear wiper motor. Rear wiper ... License plate light RH. Tail light LH.
#? license plate light - Circuit Wiring Diagrams
circuitswiring.com/tag/license-plate-light/
2008 Volkswagen Newbeetle Main Fuse Box Diagram 2008 Volkswagen Newbeetle ...Parts: rear window defogger, shift lock, battery positive voltage, interior light, A/C clutch, ... brake light, daytime driving light, wiper and washer system, vacan, fuel pump, central ... 1997 Suzuki Geo Tracker Left Dash Fuse Box Diagram.
#? license plate light - Circuit Wiring Diagrams - Page 3
circuitswiring.com/tag/license-plate-light/page/3/
Audi A4 Engine Fuse Box Diagram Audi A4 Engine Fuse Box Map Fuse Panel ... mirror control, wiper, washer, horn, brake light, cruise control, heated rear window, ... 2003Suzuki Aerio Dash Fuse Box Diagram 2003 Suzuki Aerio Dash Fuse Box ... rear defroster, fuel injection controller, radio, A/T controller, hazard light, ...
Jan 05, 2016 | Suzuki Cars & Trucks
Replacing Fuel Filter on 2007 FLHTC Harley Davidson
The fuel pump pressurizes the fuel rail/line to a high pressure in the neighborhood of approximately 58 psi. so to avoid an uncontrolled discharge or spray of gasoline, the pressure must always be bled off prior to fuel line removal and top plate removal. To do this remove the left side saddlebag and the left side cover and then remove the remove 15 amp fuel pump fuse. And then start the engine and allow the motorcycle to run until it stalls and then turn the engine over for about three seconds to remove any remaining fuel from the fuel supply line. THEN remove the maxi-fuse and reinstall the 15 amp fuel pump fuse. THEN remove the filler cap and drain fuel tank with a safe method of your choice and store the fuel or appropriately dispose of it. THEN remove the seat, the console by releasing the socket screw to release front of console from the fuel tank weldment and the hex screw to release rear console bracket from the clip nut on the rear fuel tank bracket. THEN lay a clean towel or towels on the forward part of the rear fender and lay the consoleupside down on them. Then you will need to get a special tool for Cam ring removal and installation. HD have one as part number HD-48646) which tool you will place over the top plate, aligning the four notches at the bottom of the tool with the four tabs on the cam ring. THEN get a 1/2 inch drive ratchet, install it in the tool and rotate in a counterclockwise direction until the cam ring is loose. BE CAREFUL to properly align the tool and push down on it while rotating it to loosen the ring and to control the ring because if it slips off the ting during rotation and hold both the ratchet and tool carefully so it cannot slip and slide across the fuel tank doing substantial paint damage. WHEN it is loose remove the retaining ring, insert a small plain screwdriver between the latch and top plate, depress either side of the latch, gently tug on the harness and remove the top plate by lifting it up. After you have removed the fuel tank top plate and found the ground wire spade terminal in the slot of the fuel filter shell insert the tip of a small flat blade screwdriver through the window to depress a tang, and then pull the terminal from the slot and then gently raise the locking arm and pull the U-clip from the holes in the fuel filter shell and remove the fuel filter shell from the end cap and then also remove the o-ring and filter from the fuel filter shell.
(To reinstall a new filter in the fuel filter shell seat a new o-ring on the counterbore at the top of the filter and then install the fuel filter shell over the end cap, so that the slot in the fuel filter shell engages the index pin on the end cap and then. Holding the parts together, slide the U-clip through the holes on the locking arm side of the fuel filter shell and push the U-clip until its endsexit the holes on the opposite side and then retract U-clip until contact is made with the step in the locking arm. When that is done route the ground wire from top plate TORX screw around the index pin side of the end cap and install the spade terminal into the slot in the fuel filter shell and gently tug on the ground wire to verify that the terminal is locked in place. If the ground terminal does not lock in place properly use a thin flat bladed tool to bend the tang outward slightly away from the terminal body. Then reinstall the top plate.)
THEN locate the ground wire spade terminal in the slot of the top plate, insert the tip of a small flat blade screwdriver through the window to depress the tang, and then pull the terminal from the slot. THEN depress the collars and remove the tubes from the fittings on the fuel filter shell. Move the top plate to a bench area and remove the filter (which would also be necessary it the top plate replacement is necessary and if top plate replacement is necessary, remove the fuel filter shell.
If installing a new top plate, first install the fuel filter shell. THEN inspect the seal ring at the bottom of the top plate for cuts, tears or signs of deterioration and if and as necessary, install a new seal ring with the nubs properly contacting the ring groove walls. THEN move the top plate to the motorcycle and connect the tubes to the fittings on the fuel filter shell noting that the fittings are of different sizes to prevent improper assembly such that the tube with the smaller diameter fitting runs from the fuel pump to the fuel filter housing, while the tube with the larger diameter fitting runs from the fuel pressure regulator housing to the fuel supply valve. THEN install the connector at the bottom of the top plate, route the ground wire from the top plate connector along the inboard side of the vapor valve and install the spade terminal into its slot in the top plate and lightly tug on the wire to verify that the terminal is locked in place and if it does not lock in place use a thin flat bladed tool to bend the tang outward slightly away from the terminal body so that it will lock in place. THEN install the fuel tank top plate engaging the index tab on the outer diameter in the slot at the front of the fuel tank collar, install the cam ring over the fuel tank top plate with the TOP stamp facing UP.THEN if so equipped remove the filler cap from the top plate on fairing equipped models and get an appropriate CAM RING REMOVER/INSTALLER tool and put it in place over the top plate while aligning the four notches at the bottom with the four index tabs on the cam ring and then while all the time pushing down on the tool with both hands rotate it in a clockwise direction until all four of the index tabs begins to engage with the slots in the fuel tank collar at which time insert a 1/2 inch drive ratchet into the tool and rotate the tool until the cam ring is fully installed. THEN re-install the console next by:
FLHR/C: Use caution to avoid pinching the wire harness and the vent tube. FLHX, FLHT/C/U, FLTR: Use caution to avoid pinching the wire harness, the vent tube and the overflow tube and then re-install the fuel filler cap. THEN start to thread in the socket screw to fasten the front of the console to the fuel tank weldment, start the hex screw to fasten the rear console bracket to the clip nut on the rear fuel tank bracket and alternately tighten the socket/hex screws to 36-60 inlbs (4.1-6.8 Nm). THEN re-install the seat, re-install the maxi-fuse re-install the left side cover, re-install the left side saddlebag, refill the fuel tank check to be sure there are no fuel leaks, start the engine and again inspect for any fuel leaks.
Oct 09, 2014 | 2007 Harley Davidson FLHTC Electra Glide...
How to fit extra electric socket ?
On an electrical outlet, the back of the socket has three connections. One is HOT, that is the black one. One is neutral, that is the white one. One is ground, that is the bare copper one. You can see if the connections are made to the screw on the side or inserted into the back of the socket through a hole after the wire is stripped. In either case you just add another set of wires to the socket at the unused connections and feed that wire to where you want it to go. There are several things that you should know though. Wire has a SIZE. You cannot change the size from what is already present. You have to stay white to white and black to black, ground to ground. Wire has a definite length. You cannot go far with slim wire. Lastly the number of outlets on a circuit is limited. Too many causes a potential for overloads. The electrical code is very complex and if you dont know what you are doing, you should pay to have someone that is licensed do it.
May 14, 2014 | Electrical Supplies
Mitsubishi diamante electronic door switch problem
the following checks need to be made.
All listed components are all share a fuse , and all share the same ground, G200.
Check the fuse/circuit breaker for power on both sides, if OK, follow the harness to connector C214 a 12 pin connector to the right of the glove box opening to see if there is a problem there.
Ground 200 is located on the toe plate at the front edge of the passenger's front door. Check for bad connection there.
If everything is good up to this point you will check The Black/White wire that runs through the main harness under the dash, and splits into several Black/White wires at splice S245, in the main wire harness under the driver side of the dash.
Info from: http://www.xcardiag.com/
Apr 08, 2014 | 2000 Mitsubishi Diamante
Lefthand dipped headlight not working on 05 plate renault clio, not bulb or fuse issue
You have a GROUND ISSUE, Clean the Ground to the Chassis and it will start working... You can also add a Ground Wire EXTRA to fix it faster
Apr 10, 2013 | Renault Clio Cars & Trucks
The psu is not even turning on -Jeffers help
A) You weren't FOLLOWING Anti-Static Precautions, and Static shocked your hardware components inside.
(See the little Processor ghost?
OK, OK. JUST KIDDING AROUND!
Get's pretty lonely here in the FixYa halls. Did see an Armadillo going down the hall, though. NO! For real!...........crickets chirping)
B) You don't have the main Front Panel wires, connected correctly to the pins of the Front Panel header, on the motherboard.
We'll go through them together.
C) The Power On switch is cr@P. (Did I say that out loud?)
Test it.
D) The Power Supply is bad. Weak voltage power rail.
(Got a multimeter? I'll guide you in using it.
About $5 to $12, and located everywhere. Just a cheapee Analog multimeter will do)
E) The motherboard is mounted to a Support Plate. The Support Plate can be a separate metal plate; or is part of the computer case.
Mounting of the motherboard to Support Plate, is done with plastic Spacers; or metal Standoff's.
Metal Standoff = Brass hex shaped, and with a threaded end on one side, and a threaded hole on the other.
IF, a metal Standoff is NOT matched up to a motherboard mounting hole, it can touch the exposed solder joints on the bottom of the motherboard; and short the motherboard out.
USUALLY, if the 'offending' Standoff is removed, the motherboard will work OK.
General rule of thumb is;
Motherboard mounting hole has metal ring - NO fiber washers. That's how the motherboard get's it's Ground.
Motherboard mounting hole has no metal ring? Use fiber washers.
At any rate, what is the motherboard manufacturer name, and model number;
Or,
what is the computer manufacturer, and model number.
Model number is on the back of the computer next to the Windows product key; or up on the side of the computer tower.
Post back in a Comment.
(Hurry, or I might go out with sum girlz)
http://www.directron.com/atxswitch.html
[ Need to test the three main voltages coming out of the Power Supply.
3.3 Volts, (Orange wires), 5 Volts, (Red wires), and 12 Volts, (Yellow wires) All are DC Voltage.
ALL -> Black wires are Ground wires.
In comparison two D cell flashlight batteries produce 3 Volts DC.
http://en.wikipedia.org/wiki/Computer_power_supply#Wiring_diagrams
http://www.playtool.com/pages/psuconnectors/connectors.html
Regards,
Ol' whats-his-face
(I mean joecoolvette)
Nov 26, 2012 | Computers & Internet
Headlights not working no blinkers 1987 Cadillac Deville
You have a bad ground wire somewhere. Try running a new ground directly from the battery to the body of the car, possibly attach it to a strut bolt or something handy to the battery.
Wires run along the drivers side perhaps under the carpet and door kickers or plastic plate in door jam to the back of the car. Open trunk remove left side carpet just behind the tail lights and check this wiring.
Locate the negative wire going to your head lights (only need 1 and run a new wire from it directly to the battery or the ground you made from the battery to the body.
Nov 24, 2017 | Cars & Trucks
Ground wiring
you have many grounded devices in your engine. the main ones are probably the battery ground and the alternator ground. Look at your battery, there is a Positive side (Red/Power) and there is a Negative side(Black/Ground). There is a short wire that runs from the Neg side to the wall of your engine area, it has a ring connected to a bolt. thats the ground wire. there is a similar wire on the neg side of your alternator which should be easy to find if you know what to look for.
Aug 10, 2009 | 2000 Buick LeSabre
Tail lights dont work
Oh boy, Chevy uses 3 important wires to make up their tail light harness. Brown is used for your parking lights and yellow and green are your signal and brake light wires, yellow one side, green the other. You have some seriously crossed wires. Start with tracing the lic plate lite since that works. Make sure it leads into your main parking lights and the ground wires from these tail lites aren't cut. The lic place lite will work with just power because the body of the lite is grounded with the bumper. Then make sure that there is power to the signal wires. You can do this with a test light and the signal light switched on. You don't need anyone to step on the brakes since it's the same signal, only interepted. Most importantly, Remove the tail lites and check grounds!! Good luck
Jul 02, 2009 | 1991 Chevrolet C1500
No heat in the main oven
Hi
We had the same problem - turned out to be the fan oven element - simple to fit - remove the back plate around the fan (6 screws) to expose the element. Remove screws securing element and disconnect wires (mark wires before removing) Our replacement was £40, but take the original as there are quite a few variants - you will also need the full ENR number (on side of housing) However, be aware that if this does not work, the thermostat may also have blown with the element. We were lucky as replacing the elelment fixed the problem.
Nov 26, 2007 | Neff U1661 Double circotherm super...
Lands Phones Logo
27 people viewed this question
Top Harley Davidson Lands Phones Experts
Gar
Gar
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
