You need the following OS to support Messenger Windows 2000/XP/2003/Vista/XP64/Vista64 If that is not an issue, read on.
our problem may be due to a mal-function of the uninstall software. Close all programs when uninstalling / downloading and uploading. If you tried to uninstall from the Control Panel and failed to back it up with a visit to the C drive, you may have old software conflicting with the incoming software trying to share the same folder. If you have Vista the whole Messenger folder should have been removed during the uninstall. Check Start > Computer >> Local drive (C) >> Program Files >> Yahoo >> Messenger. - The Messenger folder should have been deleted and not seen. If the Messenger folder is still visible - delete it.
If you have a pre-Vista OS, the Messenger folder remains, and inside, only one sub-folder should be seen. This is the 'Profile' folder and contains all the message history. All other software should have been deleted.
Manually delete any other folders and files before moving on
Download 'ccleaner' and run it through a couple of times.
http://www.filehippo.com/download_ccleaner/
Re-start your computer and download Yahoo Messenger from here.
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to Yahoo Messenger. COMPATIBILITY WITH YAHOO MESSENGER Use Internet Explorer to visit this page to check compatibility and automatically download the latest webcam control
CONFIGURE SOFTWARE Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the Yahoo software may have difficulty in locating it. Mine, I just unplug it from the USB and plug it back in, if yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager. Of all the chat programs, Yahoo is the most painful software to set up but if you follow these instructions you should be ok.
INTERNET CONNECTION Webcam connected Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have make sure your internet connection and country are correct in the lower two boxes > Apply > OK
TESTING > Messenger > My webcam - the warning panel will launch, click 'OK' and your webcam will start. You should be rewarded at this stage with your happy smiling face.
SET WEBCAM DEFAULT With webcam still running > Messenger > Preferences > Webcam > Camera Source - set your webcam as default using dropbox. > Camera Settings - adjust settings to suit. > Apply > OK Take a note of any additional software, if you have multiple choice for Camera Source, you may wish to uninstall any redundant webcam software later to prevent conflicts
PERMISSION OPTIONS > Messenger > Preferences > Webcam - make your selections ( who you will allow to view you) > Apply > OK
IN USE When you are both on line and wish to show your webcam > Actions > 'Invite to view my webcam'. This will launch an invitation on your contacts screen when they 'Accept' your webcam broadcast will start- There can be considerable time lag ( 1 minute) before they see you, so don't be too impatient ( You can check the status on the bottom left of your webcam panel. You can 'drag and drop' the frame to a convenient location by grabbing the top border. There is a shortcut ( webcam icon ) down by your pic as well Your contacts needs to configure their connection the same as above or they may get a "webcam not connected" message
Every time i open my YM i always gets this message Internet Explorer Script error. How can i solve...
(More)
Every time i open my YM i always gets this message Internet Explorer Script error. How can i solve it this?
When i am downloading yahoo messenger this error shown. The instruction at "0x01aa7f08"...
(More)
When i am downloading yahoo messenger this error shown. The instruction at "0x01aa7f08" referenced memory at "0x00000000" The memory could not be read.
