Question about Conair HCR1350Y Clock Radio
Need part Hummer HCR1350Y
I need the AC input part that's soldered to the PCboard. Do you have this?
Remove passenger kick panel
passenger kick panel Debra, Check the attached links,instruction and guides, 1st link will download pdf. showing how all panels are removed., Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://schwarttzy.com/wp-content/uploads/2013/01/Hummer-H3-Interior-Trim-Paneling-1.pdf
Hummer H1 Service Manual Inner Kick Panels Replacement
Body Control Module Repairing Bad Solder Joints
Mar 31, 2016 | 2006 Hummer H3
Vizio TV model # E321VA turns on and after approx. 5 seconds screen goes black and backlight remains on?
In my whole career as a tech, I never had a defect on a place I would have wanted it. And believe me, if an integrated circuit is defect, or even a diode, you won't see it on the outside of the component. Most of the time you need more than just a multimeter. Any way, to use it, you at least should have a diagram pointing out what voltages you should measure on what point. If not it is pointless.
Be aware even the 120 volt AC, can be deadly, so don't play around with that voltage.
Jan 13, 2015 | Vizio Computers & Internet
Hi, the battery cable end that connects to the hummer broke. The wires snapped due to the kids pulling it apart. Can I solder it back on or do I need to buy a whole new cable. Just replaced the...
You can probably go on amazon.com and purchase another cable far less than what the stores charge. There is a chance if you solder the wires back together that it can blow the charger completely. Cutting corners is fun, but not when it comes to electronics.
Oct 14, 2013 | National Little Tikes Hummer Yellow
A/c clutch fuse blows on 06 hummer
The AC clutch contains a field coil that creates a magnet pull on the drive plate, that field coil is shorted, replace it. You need a special puller to remove the AC pulley to access the coil.
Jun 16, 2012 | 2006 Hummer H3
Broke off my ac power supply nipple on the inside of my laptop where can I get a new one to solder on
Hi, if the Notebook is still under Warranty it is not recommended to remove and solder the Notebook with a Female DC Input socket of the Notebook. Although the DC input socket is available in any near by Electronic repair shop, please repair only if the Notebook Warranty is expired.
Mar 29, 2011 | Gateway MD7820u Laptop AC Power Adapter...
We just moved and now our Zenith PV6069RK8 has no picture. It worked great before. Now when you turn it on you get sound but the screen stays Black. Any ideas?
COMMON PROBLEM IS DUE TO COLD SOLDER OF THE SOME PARTS,BEST SOLUTION IS TO RE SOLDER THE PARTS MOSTLY AT THE PCBOARD BEHIND THE PICTURE TUBE,OR NEAR TO FLYBACK OF THE TV
Feb 28, 2010 | Televison & Video
Replaced motor on h1 hummer 6.5 diesel,we are not able to get the ac working.jumping compressor activates the system.does not use wiring from gm truck.need a print for hummer hvac
check all of your fuses and give this website a try fix trouble shoot heating & A/C www.automedia.com and another one is www.directgardening and i hope i have been some help to you Michigan Man.
May 22, 2009 | Hummer H1 Cars & Trucks
Radio is locked-need to unlock, plus unlock code
1 have h3 hummer and replaced the radio (ac delco) and is locked,i need to unlock it
Apr 30, 2009 | Hummer H2 Cars & Trucks
Conair HCR1350Y Clock Radio Logo
Top Conair Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Conair Audio Player and Recorder Expert? Answer questions, earn points and help others
