Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Will not open
My dvd recorder won't open all of a sudden. The front gives the message "open," but nothing happens. I am not sure if there is a disc in there or not. I just bought the thing in August and it worked fine up until now.
  • 70 Answers
Take it back to the store, if it is still under a year old.
If they fob you of with some bull just ask to speak to the manager, if he isn't in or wont help ask for the area manager.
AS LONG AS THERE IS NO DODGEY DVD INSIDE.
Posted on Jan 03, 2008
My DVR20KB has suddenly stopped playing and recording on DVD, I get the message Please eject the disc.Playback feature may not be available on this disc. What has happened and can it be corrected?
It could be dirt or finger marks on the disc. Try recording with a good new clean disc.
It's unlikely the current disc will play or can be used again. Have a look at the disc with it catching a light source. If there is any marks on the disc it's gone!
Dec 02, 2016 | Toshiba DVR20KB DVD Recorder
All my DVDs say "invalid" when I try and play. This just started all of a sudden. Was working just fine before.
Always first unplug for a minute and make sure the discs are VERY CLEAN. Sometimes my player/recorders give an error message 2-3 times but eventually are able to load the disc.
Mar 29, 2014 | Toshiba UNTESTED, AS IS BDX2150KU Blu-Ray...
Disk won't eject Error message: System error is detected System error is detected BE file:\Dvdv_util.c, line:264 Sensecode( 3: 2: 0), Detail:0x0
Hello
When operating, errors happen. Turn off the device.
(To turn off, press and hold the power button on the front
of the device for 10 seconds.)
After turning off, press the Open button and remove the
disc from the device
If needed reset the device to its factory settings after the disc is ejected. To reset it to factory settings:
Press the [UP] and [DOWN] buttons on
your DVD recorder simultaneously
when the power is on. All settings
including the password will revert to
the factory settings. Do not use this
unless absolutely necessary.
(Note that this function is possible only
when no disc is inserted.)
ok.
Jun 04, 2011 | Samsung DVD-R130 DVD Recorder
My DVD recorder doesn;t record. When I go to replay there is nothing on the Recorded list. (The message PSO is showing on the front of the recorder.Is this coneected?)
Ok recording is impossible.
1.this unit may not record programs that contain copy protection signal.
2.Check that there is nothing on the disc to start off with.
3.check that the disc is CPRM compatible.copy onc programmes can only be copied onto the disc which is CPRM compatible.
4.check if the the disc is protected or finalised.Undo the protection or the finalisation.
5.DVD-RW usually once formatted in another unit cannot be recorded in your unit unless formatted.
6.Check all connections are properly made.
Oct 18, 2009 | Televison & Video
Dvd disc not playing
Buy a cleaning disc for about $15.00. If that doesn't work it's time to buy a new one.
Mar 16, 2009 | LG RH1999H DVD Recorder/HDD Recorder
Sony dvd recorder rdr gx7 sending disc error message
The laser readerwriter is most likely burned out, it is the most common failure. The option of repair is not really feasible as the cost of new is really low.
May 25, 2017 | Sony RDR-GX7 DVD Recorder
Sony dvd recorder gx210
Without much more info the only thing I can think of is the lens is not homing correctly. If you are comfortable opening the unit, check to make sure the lens can move freely (from center to outside of disc). It's OK to gently move the lens with the unit unplugged.
MM85
Jul 25, 2008 | Sony RDRGX210S DVD Recorder
Unit failed to read any discs
My unit all of a sudden fails to read any discs. It just makes noises that sounds like something is stuck. Then gives the message that its a proper disc. Its says no read.
Jun 20, 2008 | Panasonic DMR-ES25 DVD Recorder
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
My RCA 8310 DVD+R/+RW -VCR Combo will not format and record on a +R disc
I purchased this RCA 8310 about 2 years ago. I have recoreded hundreds of dvd's. If I try to use anything but a Imation brand DVD+R, 8+ speed, I get the same error. It will not work with a 16+ dvd.
May 23, 2007 | RCA DRC8300N (DRC8300NWITHREBATE) Burner
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
26 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
