Question about Vehicle Parts & Accessories
Continuous chirping I have the above installed in my 2001 BMW. It has worked very well until now. It is chirping every 10 seconds, whether in city or highway mode. What do you think?
  • xscribe Dec 30, 2007
    K40 Defuser Plus 3000/SW/SWl
    I think I accepted by mistake, haven't received a reply. The model that I have is a K40 Un3000/SW/SWL
    President:
  • 1,944 Answers
Which radar detector do you have?
Posted on Dec 30, 2007
  • Damen Wong
    Damen Wong Dec 31, 2007
    Please check that everything is installed and in place as it should be (exactly like in the same state as when you installed it).
  • Damen Wong
    Check all the components to see if they have been moved or damaged.
One tire not showing pressure replaced tire sensor still not
After TPMS sensor replacement or tire rotation, reprogramming is required. 1. key on engine off, parking brake on. 2. turn park lights on and off 4 times you will hear a horn chirp twice, you are in program mode. Start at L/F tire release air for 10 seconds, wait 15 seconds until horn chirp, after chirp go to R/F tire do the same until horn chirp then R/R let air out til the chirp then L/R do the same after the L/R chirp, turn key off and you are done, note you have only 5 min. to complete. If you do not hear horn chirp at each tire, you will have to start from beginning. When complete, remember to add air to each tire, 35 psi is recommended.
Jan 27, 2014 | 2005 Chevrolet Tahoe
What does service tire monitor mean on a 2005 chevy tahoe means
It means you have a malfunction in the TPMS system. First you can try to do a reset as follows: 1. key on, engine off, parking brake on. 2. turn park lights on and off 4 times you will hear a horn chirp twice, you are in program mode. Start at L/F tire release air for 10 seconds, wait 15 seconds until horn chirp, after chirp go to R/F tire do the same until horn chirp then R/R let air out til the chirp then L/R do the same after the L/R chirp, turn key off and you are done, note you have only 5 min. to complete. If you do not hear horn chirp at each tire, you will have to start from beginning. When complete, remember to add air to each tire, 35 psi is recommended.
If that does not work you probably have a bad TPMS sensor, which will have to be replaced. Some auto parts stores will test your sensors for free, so check around.
Apr 01, 2013 | 2005 Chevrolet Tahoe
Remote says OUT OF RANGE when i try to arm it.
Reprogram the remotes using this procedure:
REMOTE TRANSMITTER PROGRAMMING
Enter:
1. Turn the Ignition 'switch ‘OFF/ON’ 3 TIMES and stay in
ON position. Within 15 seconds.
2. Push the Valet switch 2 times and hold in on the 2nd
push, when a long chirp is heard then release the valet
switch. You are now in the Transmitter programming mode.
Program:
1. Press the Lock button on transmitter 1 until the siren
responds on Car with a confirming chirp; the first
transmitter is now programmed to Car.
Exit: Turn Ignition to 'OFF' position, or leave it for 15
seconds. 3 long chirps will confirm exit.
Note: If more than 4 transmitters programmed, the system
will only keep the last four.
May 07, 2010 | Megatronix - TW71 - 5 Button 2 Way LCD...
Rotated tires now sensors do not read correctly
If you are talking about your low tire pressure sensors, theres a button in the glove compartment. Press it for 5 seconds to reset the sensors.
Feb 04, 2010 | 2005 Chevrolet Tahoe
I put in a new battery and the alarm remote does not work
Couple of times when you replace the remote battery, you might have them not working/ responding but just follow the procedure below.
Stand close to the car, hold down the open and close knobs for about 10 seconds. Press them at the same time for 3 seconds; then press the open button as the car opens.
The above procedure is applicable to a lot of car brands. It does not matter how many knobs you might have on the remote fob.
I have carried this procedure out on a lot of brands ranging from Honda, Toyota, Rover, Ford, etc. and it works perfectly well.
Good luck and Rate this.
Cheers
Dec 30, 2009 | 2001 Jaguar XJ8
Yellow oil light comes on when starting the car
The 'idiot' light only lights at about 4 pounds of oil pressure (not a good thing) or below which means that: 1. Sensor has failed (very common) 2. Oil filter may be too dirty to pass oil as it should and the bypass in it has failed. 3. Oil pump is worn and failing.
The latter two possibilities can mean that you have low pressure compared to what it should be (30-60#) but enough above 4# to keep the sensor happy.
The sensor isn't terribly costly, even on a BMW it should be less than $30 US and the labor to install it is about 10 minutes.
Jul 05, 2009 | 2001 BMW 330
BMW Engine chirping noise
sounds like a bad crankcase vent valve located underneath intake
May 23, 2009 | 2001 BMW 325
Programming the APS02BT2 remote
TO PROGRAM ADDITIONAL TRANSMITTERS:
1. Enter the vehicle, and turn the ignition key to the "on" position.
2. Press and release the valet push-button switch three times.
3. The dash LED will flash once, and the siren will "chirp" once, indicating the system is ready to accept programming for channel 1 or the arm/disarm and panic functions.
4. You can assign any of the three transmitter button functions listed below to channel 1.
a. Pressing button #1 on the keychain transmitter.
b. Pressing button #2 on the keychain transmitter.
c. Pressing both buttons simultaneously on the keychain transmitter.
5. Press and hold the selected choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of channel 1 was successful.
6. Press and release the valet push-button switch one time.
7. The dash mounted LED will flash 2 times, and the siren will "chirp" indicating that the system is ready to accept programming for the unlock/panic channel.(If you desire one button to control lock & unlock, move on to step 9)
8. Press and hold the selected remaining choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of unlock channel was successful.
9. Press and release the valet push-button switch one time.
10. The dash mounted LED will flash 3 times, and the siren will "chirp" indicating that the system is ready to accept programming for channel2, or the pulsed ground output for remote trunk release, remote car starter, etc.
11. Press and hold the selected remaining choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of channel 2 was successful.
12. Press and release the valet push-button switch one time.
13. The dash mounted LED will flash 4 times, and the siren will "chirp" indicating that the system is ready to accept programming for channel 3, or the additional pulsed ground output if available on your model. NOTE: If the program switch is operated again, the circuit will recycle through the program mode. In other words, press 1 time to access the lock function, 2 times to access the unlock function, 3 times to access the start function. When programming is complete, simply turn off the ignition switch to exit the program mode.
ERASING TRANSMITTERS IF THEY HAVE BEEN LOST OR STOLEN: NOTE: Before you begin to erase the lost or stolen transmitter(s), have all transmitters available that you wish to remain programmed. These will be used during the program process to identify transmitters that will continue to be used.
Enter the transmitter program mode:
1. Turn the ignition switch to the “ON” position.
2. Within 10 seconds, press and release the valet/program switch three times. (Siren emits 1 short chirp indicating channel 1 has been entered)
3. Within 10 Seconds, press and hold the ARM or ARM/DISARM but-ton of the first transmitter you wish to remain stored into the control unit until a single chirp is heard from the siren.(Repeat this for each transmitter you wish to remain stored in the control unit).The receiver stores up to four transmitters. To be certain all transmitter slots in the receiver are occupied with transmitters you wish to continue to use, and all others are erased, you will have to fill all four receiver slots. If in step 3 you identified one transmitter, you will have to fill the additional 3 slots. If in step 3 you identified two transmitters, you will have to fill the additional two slots, etc...
4. Press and hold any unused button or combination of buttons until a long chirp is heard from the siren. Release and press the button or button combination again and again until all remaining slots are full. NOTE: The button or combination of buttons entered will also control the armor arm/disarm function until additional transmitters are added. All unwanted transmitters are now deleted.
Feb 28, 2009 | Car APS02BT2 Transmitter for...
2001 golf hatch wont lock
Bring it back to Circuit City, they tapped into a wire to the hatch lock and shorted it out, or cut it, they should fix it at no charge.
Dec 30, 2008 | 2001 Volkswagen Golf
Grill-mounted K-40 continues to "chirp" every 10 seconds...
I too had the same problem and called their customer service. They told me 1 chirp means a front receiver fault, 2 chirps means a rear receiver fault. They suggested I check the wiring and to switch the front receiver with the back receiver to see if the error code would "travel" with it to determine if the receiever was faulty. I did that and the problem went away. I assume I had a connection that loosened up.
Jan 13, 2008 | UN 3000SW Radar Detector
Vehicle Parts & Accessories Logo
139 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
