Home | Kenmore | 16602 / 16604 / 16609 Built-in Dishwasher | Kenmore Dishwasher 587...
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Problem for Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Kenmore Dishwasher 587.15163401 knob stuck mid-cycle
By sangasong99 on Oct 23, 2009
Hi, I have a Kenmore (Quietguard) Dishwasher, Model # 587.15163401. The knob freezes half-way through the wash cycle and will run for hours endlessly, unless I manually rotate it forward. It manages to complete all the other cycles just fine.
What can I do to fix this problem? Any advice would help. Thanks. :)
Comments:
Oct 24, 2009
- I am trying to test the heating element and the thermostat with an ohm-meter. The thermostat reads .2 and then settles at 0 ohm. The heating element reads 15 ohm. Is that within standard range, or does it mean one of these is not working properly? If they are indeed fine, and it is my timer after all, how can I fix the "sticking" problem to help it advance smoothly?
Oct 25, 2009
- We fiddled with the timer a bit, then ran the dishwasher on a normal cycle (without high heat wash or dry), and it completed successfully without catching. If it catches again on the high heat wash glass cycle, then it's probably our thermostat or heating element. Your advice has helped us pinpoint the problems and eliminate suspects. :)
Best Solution
posted on Oct 23, 2009
Very Helpful)
erpaalai
Rank: Guru  Kenmore Expert
Rating: 91%, 269 votes
See if it is stuck on a water heat cycle. if the heater circuit or the thermostat is not working properly it will continue to run looking for a rise in temperature. If these are in working order the timer it self could be sticking and not advancing.
Eric
Comments:
Oct 25, 2009
- If you can, measure the water temperature entering the dishwasher and then check it again after it has "stuck". If the water is above 145 deg then the timer is bad. If the water has not heated then the element or wire is bad. The timer can sometimes be "freed" up by turning by had several times but usually ends up needing replaced anyways. There should be 120vac on the element during the water heat cycle.
Oct 25, 2009
- Congratulations, I knew you could figure it out. Thank you for the great rating.
Eric
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thanks for the help! We were able to run a normal cycle successfully without the timer catching! " - sangasong99
Popular Solutions for Kenmore 16602 / 16604 / 16609
Questions and Unsolved Problems for Kenmore 16602 / 16604 / 16609
Do you recommend Kenmore 16602 / 16604 / 16609 Built-in Dishwasher?
Answer
Answer
I can't figure out how to take apart the spray arm on my Kenmore dishwasher to see if there's... (More)
Answer
dishwasher not cleaning dishes as good as before. is there a filter that needs cleaned or changed... (More)
Answer
front control panel not working properl, cannot push start
Answer
Wont fill with water. And i out a new solenoid on it
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 16602 / 16604 / 16609...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
