Sony trinitron kv-a2542u
Sony trinitron about 12 year old keeps turning off for no reason, must be something loose inside because if you tap the top of the tele it will come back on momentarily is it worth getting repaired or are we putting good money into bad ?
  • davedoubleu Jan 09, 2008
    Well done chrispurs1, £44.50 for sony repair ,with limited funds available after an expensive christmas,your advice saved me going out and buying another tele .Your help much appreciated . THANKYOU
  • Anonymous Apr 07, 2009
    THE TV WHEN SWITCHED ON DOES NOT COME ON BUT ONLY A RED LIGHT SEEN FLUSHING
  • 372 Answers
Hi.
This is a common problem. Relatively easy to fix shouldnt cost more than £50.00 to have put right by shop.
The problem is dry solder joints 30 mins work.
http://dysonmanuals.llc.nu/
Chris..
Posted on Dec 30, 2007
I have a Sony FD Trinitron 27' Model # KV-27FV310. It is approx 8 years old. After turning it on and watching a full screen for a few minutes; all of a sudden, a line came across half the screen;
top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
May 01, 2012 | Televison & Video
My Sony trinitron tube Tv 36" seems to be going (its 10 years old
no ....the tube will end up after 20 yrs in 10 yr old sony...
it is worth if u fix it. randomly going black means...horizontal driver trans former is the problem..or any loose contact with the 110 volt supply to that transformer,,or any loose contact with line o/p transformer.. (horizontal driver transformer may be gone
then tv behaves like this) if any other parts gone tv wont come back.... there may be a loose contact call a service pro..
Apr 02, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Comes on and later goes blank
How much later? The Sony sets have a setting in the menu that turnes the TV off if there isnt' any input, Sometimes this feature gets messed up, and the feature has to be turned off, Check that out and see if that takes care of the problem.
Oct 01, 2009 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Sony Trinitron HD TV 32"
check your remote controller if it does not function there the problem might be inside the unit ..maybe its horizontal output was shorted or sometimes a loose solder in the board was the problem
Aug 18, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony trinitron TV KV-27TS27 screen remains dark
how do i adjust the brightness if i dont have the controler?
Jul 24, 2008 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Sony Trinitron 29inch Color TV
The 2 blinks are an indication of over-current. This is usually because of a shorted component. The most common is the horizontal output transistor. This will be a 3-legged part attached to a heat sink close to the flyback transformer (part with red wire coming out the top). This transistor will be marked C4856 or something similar. Update this with the exact marking and I'll provide you with the full part number and approximate cost.
Dan
Jul 14, 2008 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony Trinitron experiences
The screen control inside the set may be on the highvoltage transformer or on the crt socket; either way if you can turn it up just a little clockwise and the picture comes up but doesn't look good you are likely to have a bad tube. Or try tapping lightly on the glass neck and watch the picture as you tap. If it reacts to the tap you have a bad tube. but the turning the screen control is the best test. Turn it the other way the picture goes off immediately. bad tube: too costly if it is available.
Dec 29, 2007 | Televison & Video
Help with sony trinitron problem
Are you serious? You have used that television... in particular that CRT well beyond its predictable lifetime.  Congratulations.  Those are early symptoms of CRT failure.  Your screen may turn green very soon also.  It will occur any moment now.  It is not cost-effective to repair.  Welcome to the next generation.  You will be amazed and delighted with LCD, plasma or DLP technology. existencebeyondperception@msn.com
Oct 10, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Volume is too low on my old Sony Trinitron KV-27S45
Volume is too low on my old Sony Trinitron KV-27S45 Can i fix it with out parts? no as it requires tech help as tv is high voltage device. would it be less expensive to just purchase a new tv? it would be less expensive. no need to purchase new tv. please get check 1 speaker paper cone might be hard or defective 2 loose contact in sound section 3 supply to sound might be absent. 4 connector loose. 5 any capscitor defective in sound section. 6 ic might be defective in sound section hope this will help.
Sep 25, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Televison & Video Logo
314 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
