dear.. my LCD is no power veiw,i turn on the lamp on LCD is yellow color then after 2 seconds the color will be change oren color..so how my email hairee82h2@yahoo.com
Hello there: This is usually not a good sign I will give you a couple of things to try out first ok (1) you may want to try the monitor on a seperate computer to see if it will work if not than the monitor needs to be repaired. but if the monitor will work on a seperate computer than this just means that your video card on your computer is either loose or it is not working to test this try these steps you can try to remove the power cord and open the case and remove the power supply cord that goes to the motherboard than press the power button of the computer for 15 seconds and than if you have a reset button press this button for 15 seconds than plug the power supply cord back into the motherboard and try to reboot the machine and see if this will work if not try this (2) with the computer unplugged remove the video card and clean the gold edge with rubbinbg alcohol and let dry than reinstall than reboot the machine if still nothing than you will have to get a new video card. *** NOTE*** if your video card is built to the mother board this is a common thing cause they dont last forever so just get a new video card and install and connect the monitor to that one and not the old one ok? so please try these solutions and you should be all right best regards michael.
Was this helpful?
Yes
No
Popular Solutions for Sceptre X9G Komodo IV 19 in.
Monitor has no power (ie. no light). Has integrated pwr/aud/logic/inv board. No visible signs of any...
(More)
Monitor has no power (ie. no light). Has integrated pwr/aud/logic/inv board. No visible signs of any problems. Only have 1.6v at pwr switch, and 5v going to logic side of board. Board is model 490491200100R, can't find any information on this board.
hello. how did you reset the eprom on the lcd monitor? my monitor turns on for 2 seconds then shuts...
(More)
hello. how did you reset the eprom on the lcd monitor? my monitor turns on for 2 seconds then shuts off. i took it apart and when i lift the glass and put i flashlight behind it i can see that the monitor works but the bulbs are not turning on. is there a way to apply separate power to the bulbs?
just like antdotwhat my monitor started doing the same thing as theirs on the same date. I turned...
(More)
just like antdotwhat my monitor started doing the same thing as theirs on the same date. I turned on my computer and the on light flashed on and of constantly this time with a black screen. I turned the computer off and back on and the monitor started working properly. This morning I turned it on and same thing. I tried turning the computer off and this time it would not work. I tried this several times. I think the monitor is no good anymore.
