Question about GE Refrigerators
GE PROFILE PTS22LHPARWW ICEMAKER NOT WORKINNG
Initially, little drips of water were forming an icicle on the backend of the maker and into bucket. Then just the other day, I found ice on top of the harvest ''fingers''/arm and down onto the paddle. Then it stopped making ice.
I took these steps:
1) unhooked rear refrigerator vinly tubing from the copper feed coming out of the wall to make sure water was not blocked with ice-- verified water was coming from the copper tubing from wall.
2) removed unit from refrigerator and defrosted it, but there really was not any ice down in the form.
3) reconnected unit, green light lit and then I pushed in arm 3 times to enter diag mode. DIAG results: water entered unit, cubes froze, and arm pushed very small cubes out.
After that, the unit made a FEW cubes - mostly small. I thought I had turned the water pressure down too low, so I increased the water pressure to the copper tubing. The icemaker made 1 set of full sized cubes and stopped making any more.
I then took these steps:
1) powered off unit, powered back on, and entered diag mode: water entered, froze and arm swept tiny cubes out. IT MADE NO MORE AFTER THAT.
2) powered off unit, powered back on, and entered diag mode: water entered, froze, and then it did not eject cubes -- they stayed in unit for over 24 hrs.
3) powered off unit, powered back on, and entered diag mode: water entered on top of cubes still in unit, probably froze and then a short while later I heard it eject cubes. IT HAS NOT FILLED UNIT SINCE THEN.
paddle moves back and forth fine; harvest arm is not jammed; water enters unit when I put it into test or diag mode; WHAT IS WRONG WITH THIS THING?!???!!!
Change or remove filter
change control valve
change valve on copper water ine
change copper water line
check input pressure to unit
25? 25? anybody know what is the minimum water pressure supposed to be entering the refrigerator icemaker?
Posted on Jul 07, 2010
SOURCE:
My icemaker 106-626636 is making ice but it is also making icicles and dripping in the bucket to where i have chunks of ice melted together. the icicle is where the black part of the icemaker meets the...
The problem is not the icemaker. It is the solenoid water fill valve in the back of the unit. You make have to use a hair dryer to defrost the water fill tube just behind the icemaker AFTER you replace the water valve. I just worked on my own and have have done in home appliance repair for over 30 years. If it is making icicles the diaphram in the water valve is shot. It is not a difficult or expensive part IF you order it on the net. Walk in replacement part prices have nearly a 100% mark up.
Thanks for choosing FixYa.
Kelly
Aug 18, 2010 | Refrigerators
Stainless Steel GE Profile with Bottom Freezer.
Have you had any cooling problems coincide with the ice problem? if no evidence of temperature variations, you either have a crack in the ice maker mold, causing water to drip into the ice bucket. Or you may have a bad water valve solenoid, not closing completely when the ice maker stops calling for water, overfilling ice maker into the bucket, and further down your freezer.
those are the most common problems, though other odd situations could also be a problem.
Mar 28, 2010 | GE Profile Stainless Bottom-Freezer...
No ice instead water dripping down into freezer making icicles
If you have icicles, where are they forming at? If on the front of the ice bucket, then look at the dispenser shoot door is closing all the way. The way to check that is to look into the shoot while holding a flash light (or bright light) up into the dispenser from the front side of door. You should see no light.
Now if you have ice buildup around the inside of bucket, mainly from the ice maker to the bucket then you either have an ice maker that is leaking water or you have a water valve that is not shutting off all the way. Suspect water valve if you have ice buildup within water inlet tube on top of ice maker. Frozen water within tube is good indication that water valve is leaking.
Look inside refrig side of refrig, usually located on right top side of wall, you will find a tag with model number and serial number. Need both to get you the right part number for ice maker or water valve.
Oct 08, 2009 | GE Profile PSW26P Stainless Steel Side by...
Icemaker leaking
Check two things.
1: see if you have ice buildup in the water inlet tube above ice maker, if you do chance are the water valve is bad, if not,
2: see if you have icicles hanging from bottom of ice maker, if you do you have a bad ice maker.
Either way, will need full model number and serial number both to get you the right part numbers for parts.
Oct 07, 2009 | GE Profile PSW26P Stainless Steel Side by...
Icicle are forming around icemaker port inside of
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Sep 17, 2009 | Kenmore 53542 / 53544 Side by Side...
Icicle are forming around icemaker port inside of freezer compartment drips seem to come from around inmaker feed water area.
Sep 17, 2009 | Kenmore 53642 / 53644 Side by Side...
Ice maker dripping water fusing ice cubes
The dual water valve (solenoid) that open and let the water from the line when the ice maker calls for it, is leaking and needs to be replaced.
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker is dripping and forming an icicle at the front right of the ice maker
you need to defrost the drain hole and clean it out... sounds like it is frozen
May 23, 2009 | Maytag MSD2756G Side by Side Refrigerator
GE Profile Side by side- lines from custom cool covered with ice
I can't give you a solution but I can tell you that we have exactly the same situation. The freezer seems to work but we come back and water has dripped from the ice holder and formed a classic stalagtite (or is it a stalagmite?) Obviously something has melted. We have also found items in the freezer melted - yet the digital readout said it was 3 degrees! Arghhhhh. Glenn in Delaware
Apr 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Icemaker leaking causing icicles
Is it overfilling with water? If so, it may be an problem with the fill valve leaking slightly. I say slightly because if it were a large leak, the freezer would have frozen puddles in it. Also check the water chute to be sure the water is all going into the freeze tray. Sometimes they can work loose.
If the seam is leaking, there could be a crack in the housing - not sure that's repairable - sometimes epoxy will work (5 minute, 2 part) but it can be difficult for glue to hold on the type of plastic used in an ise maker housing.
Mar 27, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerators Logo
170 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Matt Sicignano
Level 1 Expert
