the flash keeps strobing uncontrollably and is driving me nuts! Also sometimes the auto focus goes in and out a million times and will never let me take the picture.
In some instances these problems are related. Either your film speed or shutter speed are set incorrectly for the lighting.
Strobe can be set to OFF in setup. Although it does help with ensuring you have the subject correctly framed before shooting in dark or lowlight situations
AF problem,,can be distracting objects near lens.. dirt on lens
wrong weighting selected.. try centre.. those red boxes you see when you press the shutter button and look through the eyepiece.. they form a cross generally If you have only one side weighted then the AF may sometimes play up.
read the manual carefully to understand some of these things. It will pay off with better pics
insufficient light wrong shutter s[peed wrong ISO ( film speed) as related to old ASA for film camera set to macro mode indstead of normal please rate my help++++Thanks for using FIXYA
Was this helpful?
Yes
No
Popular Solutions for Olympus EVOLT E-510 Body Only
I guess the solution to my E510 pop up flash creating a shadow when my 9-18mm lens is on, is to use...
(More)
I guess the solution to my E510 pop up flash creating a shadow when my 9-18mm lens is on, is to use the external flash. Too bad Olympus didn't think of this earlier. Any other thoughts?
olympus e-510 software freezes after a few shots and the is locked. needs to shut it off or in some...
(More)
olympus e-510 software freezes after a few shots and the is locked. needs to shut it off or in some cases take out the battery to have it unlocked and to be able to take a few shots again
the on off switch doesn't always work. you have to fiddle with it to get it to work. and if you turn...
(More)
the on off switch doesn't always work. you have to fiddle with it to get it to work. and if you turn the mode wheel or just tape the wheel gently it switch off again. is there a solution?
Olympus e510 Appears to be similar to some below. Recently autofocus, and shutter do not clode in...
(More)
Olympus e510 Appears to be similar to some below. Recently autofocus, and shutter do not clode in P, S or A modes, although the camera functions as normal in Auto or the pre-configured scene modes. Any ideas?
